Old 01-29-2004, 12:26 PM
motorjock205's Avatar
motorjock205 motorjock205 is offline
Send a message via MSN to motorjock205
Unhappy 96 Mustang GT AntiLock Brake Problem
[color=navy][font=times new roman][size=7]I just bought a 1996 Mustang GT, and have experienced two occasions of emergency braking and found that the ABS is not working. I know it has ABS, all the components are there, but the ABS light does not come on in the dash when I start the car, and I can see that there has been a recent brake job done on the car (ie. new pads, calipers are painted red). All fuses are ok, but ABS is obvioiusly NOT working as it should. Any help here would be greatly appreciated.
Old 01-29-2004, 05:12 PM
GTStang's Avatar
GTStang GTStang is offline
Stang Guy
Send a message via AIM to GTStang
Did you check the ABS relay?
R.I.P. Hypsi- Andy your one of the best people I ever had the priviledge to know. AF and the world
has lost one of the truly wonderful people...
Old 01-29-2004, 07:58 PM
SIKCRX SIKCRX is offline
Re: 96 Mustang GT AntiLock Brake Problem
im not sure if you know this or not, even with ABS your brakes will still lock up, then ABS kicks in and smoothes it out. then ABS goes away and kicks back in...thats basically the general idea.
Old 01-30-2004, 06:53 AM
Any way to check the ABS Relay other than replacing it???
Old 01-30-2004, 06:54 AM
Yes, I know how ABS works, but when you lay down 30-40 feet of solid skids and the pedal is not pulsing, something is definately wrong!!!
Old 01-30-2004, 06:57 AM
Any way to check the ABS relay other than replacing it???
Old 01-30-2004, 02:24 PM
GTStang's Avatar
Stang Guy
Ummmm do you know anything about electronics, multimeters and how relay(switches) work? There is a way to test it but you kinda have to know that stuff. If you don't the relay usually costs about $10 and can be switched in 5 minutes tops.
Braking Problems frehleycomet Tracker 2 03-29-2009 10:46 AM
Mustang II brake problem Michigan Rick Mustang Problem Diagnosis 1 04-11-2008 12:21 AM
Antilock Brakes problem sudzyguy C/K 10 02-05-2005 02:17 PM
