Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 04-10-2008, 07:57 PM
Michigan Rick Michigan Rick is offline
Mustang II brake problem
I am just getting my vehicle out for spring. The brake pedal goes to the floor. So I filled the master and bled all lines and got pedal pressure. I start the vehicle and the pedal goes away. A friend says I need a new booster. He says to suck on vacuum line to see if it holds pressure. It does unless I move the rod that goes into the master....than it leaks air . Is it the booster leaking or ???
What is the correct amount the rod from booster goes into master.? Should it be touching inside master or ???
Rick
Old 04-11-2008, 12:21 AM
351wStang's Avatar
351wStang 351wStang is offline
Re: Mustang II brake problem
I suggest replacing the master cylinder and booster together.
1969 Cougar
357w & TKO - 475hp
