Old 01-29-2004, 10:19 AM
Pmpjuice824 Pmpjuice824 is offline
power problems !! :(
when i listen 2 my system, my head lights dim.. my head unit dims.. all my lights on my car dim.
my car is a honda civic. so i know the alternator doesnt put out alot of amps.. only about 73 amps. and i got a stock battery. i was thinkin about buying the opti. battery. does anyone know how i can stop that so my lights wont even dim at all..i got $500 to spend. any sugestions ?
Old 01-29-2004, 04:55 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: power problems !! :(
upgrade the big 3 first to 4ga or bigger (add them to the stock wire, don't replace it, more wire is better)
alt + to batt +
batt - to ground
engine to ground
That should REALLY help, if not kill your dimming issues. If you still have problems then you can go for a new battery if your stock one is old or bad, or you could get a HO alternator if you want.
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 01-29-2004, 05:05 PM
swedish swedish is offline
get a capacitor such as this
my friend use to have a beater ford tempo, w/ a sound system that damn near turned his headlights off, he got one of these and it was fine
"One great big festering neon distraction,
I've a suggestion to keep you all occupied.
Learn to swim."
Old 01-29-2004, 05:59 PM
sr20de4evr's Avatar
don't waste your money on a cap, atleast not until all over avenues have been persued
'01 Black Sentra SE
'05 Silver WRX STi
Old 01-29-2004, 06:18 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Re: Re: power problems !! :(
BANDAID SPEACH!BANDAID SPEACH!BANDAID SPEACH!BANDAID SPEACH!
www.cloudcity.deviantart.com
Old 01-31-2004, 09:46 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
caps work for some cars and not for others, sugeest you TRY it first - before shelling out $100+ for one
the real problem is that the load on the cars electrical system by a large amp is not straight DC, it's pulsed DC - more like an AC wave, so the impedance of the wire (in this case the iductive reactance). This is so because the power input is controlled by a pusle with modulation circuit.
loss of power impala03ryder Impala | Impala SS 2 10-10-2010 10:24 PM
'95 Passat FL power window problem frescoraja '93 - '96 1 06-19-2010 01:44 PM
88 Caprice Power Issue mbronzino Caprice 3 04-28-2009 11:21 PM
`99 Power Window Problem.. beadlingi Prism 0 04-27-2009 06:13 PM
98 power window express down problem fliplover Monte Carlo 1 04-03-2009 11:48 AM
