Old 01-29-2004, 09:43 AM
blazergal blazergal is offline
95 Blazer
First Thanks for the information you supply. My 95 Blazer will turn over but is hard starting unless I turn the key on and leave it there for 3-5seconds then it starts first time. This only happens after it sit over night or in the parking lot at work for 8-9 hours. After first start it starts first try. We changed the relay as was suggested, didn't help. Since it does start and runs well, don't thing it's the fuel pump. Any other suggestions? Blazergal
Old 01-30-2004, 05:23 PM
C_Sephiroth's Avatar
C_Sephiroth C_Sephiroth is offline
Send a message via AIM to C_Sephiroth
Re: 95 Blazer
It accually might be the fuel pump. Or you have a REALLY resticted fuel filter.
Homer: No T.V. No Beer makes Homer go... Something Something or another..............
Marge: Go Crazy......
Homer: Don't mind if I do.....muahahahahahbwauauauauauauau
Old 02-02-2004, 09:42 AM
Re: Re: 95 Blazer
Thx we will be dropping the tank this week to relpace the fuel pump. It is getting hard to start in the morning.
Old 02-02-2004, 09:53 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Before you do that, pull your upper plenum and check for signs of washing. (since it's a 95, ill assume you have CPI. Washing means one side is cleaner than the other) IF the passenger side is washed, you have a bad cpi, if the drivers side is washed, you have a bad nut kit. Either one of these can cause these symptoms. Also you might want to pull and clean the egr with carb cleaner and a stiff wire brush...(make sure the pintle is free flowing)
Old 02-02-2004, 01:25 PM
Re: 95 Blazer
Decided to try the fuel filter first afterall. Fired up first try but the big test will be tomorrow morning. Thx for suggestions. Blazergal
Old 02-02-2004, 01:44 PM
rlith's Avatar
Re: 95 Blazer
Well, good luck! I hope that's all it was
94 s10 blazer 4wd 4dr 4.3 parting out chevyshitsonford Classifieds 9 10-27-2016 09:35 PM
2000 Chevy Blazer won't start after replacing blazer AustinJ! Blazer 5 02-27-2005 10:14 AM
dash swap 1998 blazer dash into a 1996 blazer dankdog Blazer 1 02-22-2005 06:38 PM
2000 Blazer -- Is it a cpi or tbi -- And what kind of Blazer? starla3366 Blazer 33 09-14-2004 05:56 PM
starter from 86 s10 blazer fit & work in 88 s10 blazer help pleEASE!!!! juzdose S-10 1 12-20-2003 06:36 PM
