Old 12-19-2004, 08:56 AM
AustinJ! AustinJ! is offline
2000 Chevy Blazer won't start after replacing battery
Battery died, and I replaced it yesterday. After replacing the battery the blazer started. I let it run for about 5 min and shut it down. I tried to start it again 1 hour later, and although it spins over, it will not start. I checked fuses, owners manual, chilton's repair manual, and cannot find the cause. I talked to a local shade-tree mechanic, and he told me that after replacing a battery there is a certain sequence that must be followed in order to re-set the computer to let it start. Does any of this make sense? If so, does anyone know this sequence?
Old 12-19-2004, 08:59 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 2000 Chevy Blazer won't start after replacing blazer
Not really. No real sequence.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 12-19-2004, 11:19 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
The only time you will have an issue is scrambling the passlock system. If that is what happened(doubtful in your case because you ran the car after the battery change) You need the passlock code to program into your radio to restart the car. Is your security light on the gauge cluster flashing?
Old 12-19-2004, 11:44 AM
Re: Re: 2000 Chevy Blazer won't start after replacing blazer
Yes, The security light is flashing.
Old 12-19-2004, 11:45 AM
rlith's Avatar
Ok, call the dealer, give them your vin, they will give you the code that needs to be entered in through your radio and you should be fine.
Old 02-27-2005, 10:14 AM
jalad82 jalad82 is offline
Send a message via AIM to jalad82 Send a message via Yahoo to jalad82
Security Light
Hey guys i got the same issue my security light is sold. 1st time i try to start the car wont start but the 2nd time it does. is there any way to fix this problem. please let me know in details cuase i know nothing about cars.
