Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 01-27-2004, 09:28 PM
ShandyG ShandyG is offline
Question Windsheild Wipers positioned in front of driver's side when off?
We just got almost 12 inches of snow where I live and when I went to start my car and turn on the wipers to clear my windows the wipers worked fine the problem started when I tried turning them off they no longer stop at the bottom of my windshield....instead they both stay up in front of my drivers side....anyone know what the problem could be???
My dad had mentioned that the motor got wet and that is why?? If so then will they reposition themselves once the motor has dried up?!
Old 01-27-2004, 09:52 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
snow or ice keeping the motor from working correctly.
Take some warm water, dont go crazy w/ the temp of the water dont want you to crack the windshield, and poor by the bottom of the wipers. It will melt the snow/ice that might be keeping your wipers up.
Give it a try.
Tim
Old 01-28-2004, 08:59 AM
Sgt 007 Sgt 007 is offline
Re: Windsheild Wipers positioned in front of driver's side when off?
Another thought... your wiper arms may have stripped out. The arrms are made of really lightweight metal and strip easily. They are held inplace with a nut connecting to the motor shaft. Take your car inside to work on it, or at least get all ice/snow off the car. Remove the nut, and then remove the wipers (careful not to damage the wiper fluid lines). Check to see if they are stripped badly. If not, reposition them in thier resting position, and tighten the nut. This may work even if they are stripped slightly, but don't use them to wipe lots of snow off the windshield. After retightened, check for operation. This should suffice until you can get new ones from the dealer, junkyard, etc.
Old 01-31-2004, 02:16 PM
prinah prinah is offline
Post
This is a common problem on this GM wiper system, the wipers will work fine when on, but park in a poor location.
The end of the wiper motor has a stamped steel plate attached to it with a formed tab. This tab acts as a location indicator for the motor when you switch to the off position (i.e. reverse the motor to retract the blades). In some instances the tab can become bent slightly, enough so that it will not contact at the proper stop point. Subsequently, the reversed motor continues to turn until is jams against some other area, not the intended toggle.
I had this exact problem. It is an easy fix, but time consuming. You must remove both wiper blades (make note their position on the spidles, this will help later during installation). Then remove the plastic cover that shields the drive assembly. On the drivers side wiper you will see a odd shaped flat plate with a formed up tab. From the factory this tab was bent at 90 degrees, you will likely find it to bent due to stress. With a solid screw driver and pliers it can be bent back to its correct location.
Old 02-01-2004, 06:38 AM
kilroypr's Avatar
kilroypr kilroypr is offline
Send a message via MSN to kilroypr Send a message via Yahoo to kilroypr
Good to know, the shop would make you get a new wiper motor just because of the fricking steel plate bent incorrectly.
Old 02-01-2004, 07:02 AM
theguru theguru is offline
Banned
I also think there was a factory recall on the wipers for this exact reason. I think they reinforce the end tab. Check with your local Pontiac dealer (service department). If I am not mistaken, I got a letter in the mail about this and had it fixed (they do it for free if it is a recall) when I had other work performed on my car. Check it out.
Old 02-01-2004, 09:58 AM
Flatrater's Avatar
Flatrater Flatrater is offline
Main GM Guy
The recall you mentioned was checking to see if the crank arm has a black plastic cover over it! This problem is not a covered warranty item. Turning on the wipers when they are frozen to the glass or when you turn the wipers on when the glass is covered with snow and ice is your cause. Only thing to do is make sure the wipers are free and clear of snow/ice.
Yes this is a common problem but it is caused by the owner's improper use.
Shop Foreman Buick Pontiac and GMC dealership
ASE Master Tech
ASE Advanced L1
GM Master tech
Licensed Aviation mechanic
Old 01-09-2005, 02:07 PM
BentCoinReturn BentCoinReturn is offline
Hey GP enthusiasts/owners... please bear with me. I am new to the site and have been reading for the last few days with interest in the knowledge I see here. You folks make it all sound so easy... Unfortunately, I am having a problem with my 2001 GP wiper "parked" in the up position. I planned to do exactly what has been recommended here, but I can't find a release clip on the base of the wipers to remove them. Does anyone have the answer?
Old 01-09-2005, 05:18 PM
dlondon dlondon is offline
The problem description and solution offered by Prinah was right on the money for my 1997 Pontiac Grand Prix GT that had the same problem. After a considerable ice and snow storm, the wipers would work fine when on, but then move to straight up position on the windshield when turned off. The metal tab being bent was indeed the problem. The advice saved me a trip to the dealer. I was sure glad to have researched this on the forum. Thanks for the help
Old 01-09-2005, 05:21 PM
Re: Re: Windsheild Wipers positioned in front of driver's side when off?
I'm not sure about your 2001, but my 1997 Grand Prix GT has a plastic cap you remove to reveal a 1/2" nut that secures the wiper to the shaft.
Old 01-09-2005, 06:38 PM
Re: Re: Re: Windsheild Wipers positioned in front of driver's side when off?
I have taken the plastic cap off and removed the 1/2" nut. I still haven't been able to get the arm off of the shaft. It doesn't appear to be corroded or something that simple.... I've twisted, pulled, pried, and still can't get ot off.
Old 01-09-2005, 07:20 PM
Chazman Chazman is offline
http://www.automotiveforums.com/vbul...d.php?t=333857
Old 12-11-2006, 10:49 AM
Slow5.0 Slow5.0 is offline
Send a message via AIM to Slow5.0
Guy at work have same problem on his 96 Grand Prix SE 2 door and 02 Monte Carlo SS
Old 12-11-2006, 11:37 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Sorry but please do not resurrect old threads. If you have information of benefit to this forum then start new thread. Any thread over 3 months old is classified as old. Thread closed.
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
Timeslip 08/12/06
AF Community Guidelines
noise in front/driver's side, 97 mountainner horseyjen Mountaineer 14 07-12-2015 10:30 PM
Front driver's side wheel squeaking non-stop- what is it? 2talll Explorer | Explorer Sport Trac 9 04-29-2006 03:58 PM
chewing sound from driver's side when steering to left ONLY. dushanya Neon | Plymouth Neon 7 03-13-2006 12:36 PM
2001 Sierra passenger windsheild wiper position. BCMaxima Sierra 0 05-17-2005 10:16 AM
2001 325 driver's side window off it's track elbee 3 Series 3 08-31-2004 06:36 PM
Closed Thread
