Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon
Old 03-09-2006, 02:40 PM
dushanya dushanya is offline
chewing sound from driver's side when steering to left ONLY.
Hello to everyone.
My steering pump is of bc of A/C is down, so when I turn a wheel in a morning its kinda chewing rubber and some undescribable sounds along with it. I checked under - nothing is visibly worn-out or in scratches. After while/driving noise getting of almost completely.
Any ideas will be greatly appreciated.
Neon Highline '95
Sincerely,
Andrew
Old 03-09-2006, 11:21 PM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: chewing sound from driver's side when steering to left ONLY.
Have someone turn the wheel to the left, while you try to see where the noise is coming from. Is it the tire rubbing?
Old 03-10-2006, 07:47 AM
No, tire is ok. but definately rubber-chewing sounds+some scratching as well but rubber at most.
Thank you for reply.
Andrew
Old 03-10-2006, 07:59 AM
onerchprk onerchprk is offline
Send a message via MSN to onerchprk Send a message via Yahoo to onerchprk
Sounds like the half shaft is shot on the right side
1997 Aerostar (239,000 Miles)
1993 Aerostar (189,000 Miles)
Old 03-10-2006, 08:03 AM
Hello everybody,
Could you describe a bit more, please.
Regads,Andrew
Old 03-10-2006, 08:24 AM
On front wheel drive cars you have a drive shaft that puts power to the wheels. When the constant velocity join inside the black boot goes bad it makes a grinding clicking sound. Check the boots for any tears as they probably leaked all the grease out. It is cheaper and easier to just replace the whole assembly then the cv joint itself. It is a fairly easy job.
Old 03-10-2006, 08:51 AM
Thanks for the input.
Although I was looking under and on these 2 boots, one near the wheel one on the axel. Do not see any tear-offs, leakege, drippings, all in their manufactured shapes, nice and dusty.
And why would it almost desappear after 3-4 turns? There something may be in trani but I have no intention to split it apart. Another thing: When I lifted the car and let it running and turning - no noise at all.
Thank you all,
Andrew
Old 03-13-2006, 12:36 PM
ozzman87 ozzman87 is offline
probably not your cv joint. if it was you should hear it anytime you turn and it wouldn't go away. it would also be more of a constant knocking sound that would vary with your speed. have you checked all your rotating parts. (hub, bearing, rotor, etc.)
