Old 01-27-2004, 01:48 AM
wickedplastikman wickedplastikman is offline
remote start and hondata??
ok, two questions. if i get a remote start on a manual, i need to bypass the clutch sensor. my hondata has a rev limiter for launch that i think is dependant on the clutch sensor. i also have an overall rev limiter and full throttle shift. will any of this be affected if i bypass the clutch sensor?
and, what is a good brand of remote starter to buy without one of those fancy lcd remotes? those break easily in my experience.
Old 01-27-2004, 07:33 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: remote start and hondata??
any of the higher end names from Directed Electronics I would pick. No, your otherstuff will not be affected by bypassing the clutch if you use a relay to do it. DEI is comming out with a 2-way LED remote which is said to be much cheaper than the LCD but it hasn't shipped yet.
Old 01-27-2004, 11:48 AM
what kind of relay are you talking about. i was just thinking of the old cut the wires and solder technique.
Old 01-28-2004, 05:58 PM
Re: Re: remote start and hondata??
I was talking just about a standard SBD relay unless you meant to permantly disale the switch. If you want to do that, just unhook the switch. My method, the switch would still work when the RS is not engaged.
Car starts with remote but not with the key?! lilvicklynn Accord/TSX/Accord Hybrid 2 11-14-2010 12:10 PM
Remote start and lights out after replaced fuel pump onetime_77 Silverado 0 08-21-2006 02:42 PM
Python Remote start and the 455T module lrffemt Grand Cherokee | Grand Cherokee SRT8 0 11-30-2005 03:31 AM
viper remote start and alarms itsmecorr Car Audio 2 06-07-2004 09:31 PM
Remote Start and Keyless entry system help sageuvagony '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 6 03-16-2003 06:59 PM
