Old 03-12-2003, 06:28 AM
sageuvagony's Avatar
sageuvagony sageuvagony is offline
Send a message via AIM to sageuvagony Send a message via Yahoo to sageuvagony
Unhappy Remote Start and Keyless entry system help
About 2 months ago I had bought a Keyless entry and remote start system. Sadly I still have it because I have not been able to install it. The instructions at first were a little confusing but then I kinda got the point. Now the problem is that I cant really find any of the wires it asks for. The first wire it asks to look for is the +12 VDC Battery 1 source wire. Then the +12 VDC Battery 2 source. It says I can find these at the Vehicles ignition switch. The truth is I have no idea where that is. Im guessing these wires are under the steering wheel right? but how do I know which color or wires they are? I feel so stupid because of this. Here is the list it needs.
+12 VDC Battery 2 source (if the car has one)
Starter output wire (should have +12 volts when trying to start)
Ignition 1 output
Ignition 2 output
Accessory Output
Chassis Ground source
Control switch
and there are a whole bunch more. I just want to know where I can actually locate any of these wires. If they are really under the steering wheel, how can I find out which is which? I have a Haynes repair manual but its wiring diagrams dont help too much at all. Kinda hard to read. I REALYYYYYY Need your help on this one. I Paid 70 bucks for this and everyone is charging me 200 bucks to install it. I think its kinda crazy.
Old 03-12-2003, 06:50 AM
94civic's Avatar
94civic 94civic is offline
all of the wires for remote start you can find the wires under thesteering wheel.
the 2 +12 vdc goes to the white(constant +12) wire under the sterring wheel
the starter output goes to the black/white(starter) wire
the ign 1 goes to the black/yellow(ign) wire
the ign 2 goe to the yellow(heater/a/c) wire
the ground all you have to do is find a screw or bolt anywhere under the dash that is attached to metal and just unscrew it, put a ring terminal on the end of the wire, if there is any paint on the surface of the metal then scrape it off then put the ring terminal through the bolt and screw it back in.
the other two wire you are going to have to give me more info on those cause they can be used for anything.
1994 civic ex - b16a sir2 w/lsd
too much to list
http://www.cardomain.com/memberpage/423478
Old 03-12-2003, 07:17 AM
Thank you so much for your help so far! If you can actually help me go through with this I'd pay you. I have had this thing for a while and would love to get it installed! Do you have AOL or AIM by the way? The installation manual is this link below
http://www.audiovox.com/manuals/inst...285850A_IM.pdf
Do you think its worth installing? is it hard? is it a waste of time? Please let me know.. and THANKS!
Richard
Old 03-12-2003, 07:28 AM
Here are pictures of my wires... I hope it helps a little... and if you could draw on them it would help alot Thanks
http://members.tripod.com/Meechue2/wires.htm
Old 03-12-2003, 10:59 AM
94civic's Avatar
are you trying to hook up the remote start or the remote start and keyless entry.
too much to list
Old 03-12-2003, 11:02 AM
94civic's Avatar
1992 Honda Civic Security Information
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Accessory Yellow Ignition Switch Harness
Tach Blue Distributor
Brake Switch Green/White Brake Switch
Trunk Pin Green/Black (-) Above Fuse Panel Blue Connector
Parking Lights Red/Black Above Fuse Panel White Connector
Head Lamp Red/White Steering Column
Hood Pin n/a
Factory Disarm Disarms w/Unlock
Door Trigger Green/Red (-) Driver's Running Board One of Two Wires
Door Lock Green/White (-) In Driver's Door at Door Lock Module or at Anti-Theft Module under Driver's Seat
Door Unlock Green/Red (-)
Horn Wire Blue/Red (-) Steering Column, use Relay
Windows Up LF=Red/Blue, RF=Blue/Yellow
Windows Down LF=Red/Yellow, RF=Blue/Green
too much to list
Old 03-16-2003, 06:59 PM
LiLJami LiLJami is offline
Send a message via AIM to LiLJami
Well you've got the colors for your wires now but I'm guessin ur still confused, just as you should be. Installin remote starts is not easy. Trust me, I know. It's what I do for a living. If you want me to help you out just email me at [email protected]. I have a 95 civic that i put a remote start and alarm on so I'm bettin i could be of help. My aol name is liljami95.
See Pic of the truck here!!!
Email = [email protected]
AIM = liljami95
Nissan Sentra keyless entry module location serge_saati General Discussion 2 06-26-2010 10:03 PM
remote keyless entry problem smity9089 Intrigue 0 04-13-2009 11:45 PM
