Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 01-26-2004, 07:08 PM
bonsai3s bonsai3s is offline
Unhappy 1988 Honda Prelude si
We have a 1988 Honda Prelude SI. I am not mechanically inclined but would like to kindly ask for directions in my first attempt to fix this car. 1. The fan went out. What should I check first?
2. The a/c works but stops regularly.
3. Just today, I moved the car from the driveway into the garage and discovered the steering fluid boiling and overflowing.
I am humbly asking for any assistance from anyone out there. Thank you. Efren email: [email protected]
Old 01-29-2004, 09:13 AM
sofast's Avatar
sofast sofast is offline
Send a message via AIM to sofast Send a message via MSN to sofast Send a message via Yahoo to sofast
1. Check the fuses for the fan first. If that doesn't work try hooking the fan directly to the battery to make sure it even works.
2. Tha a/c may be low on compressor oil or refrigerant. in this case the a/c will turn on and off. chances are you have a small leak if this is the case. You can have a die test done to find the leak. I would have it filled with 134a refrigerant. Its cheaper.
3. never heard of a pwr steering pump boiling in such a short trip. I cant give you any help with that.
Hope you get it figured out
Old 01-29-2004, 06:14 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
Re: 1988 Honda Prelude si
www.preludepower.com
you won't be disappointed by the 3rd gen forum.
