Go Back   Automotive Forums Car Chat > Chrysler > LHS
Old 01-26-2004, 02:34 PM
bluzplayer_03 bluzplayer_03 is offline
Send a message via Yahoo to bluzplayer_03
Question 97 LHS is hard to start
I just put new head gaskets on my 97 LHS. 3.5 L. Had the heads reworked, etc. Everything went fine, and it took only 4 seconds to start up the first time, and all I had left over was one blue O-ring from the job...
Problem is...now it ALWAYS takes 4 seconds of cranking to start, hot, cold, whatever. It runs great, smooth as silk, lotsa power, good mileage, etc. But it's slow to start and I'm wondering if the starter motor just isn't spinning it fast enough, or was that O-ring from teh fuel rail causing a lag time in getting fuel to the injectors somehow?
I can't find details on how to reassemble the rails. They're not leaking, car seems fine otherwise, but I wonder if it's fuel delivery on startup that's making it slow to start. How might i diagnose this? I'm a skilled amatuer, but have no fancy diagnostic equipment.
Thx for being here, guys.
Ed aka bluzplayer_03 in Dayton Oh
Old 06-30-2004, 06:38 AM
rambis340 rambis340 is offline
Same issue on 96
I have the same problem on my 96 LHS. It takes about 4 seconds to start. It runs great once started. Did you ever find a solution to this problem??
Old 06-30-2004, 07:47 PM
Re: Same issue on 96
No, I haven't found the solution yet, but honestly was not really looking till I found some help here, which hasn't happened yet, obviously. Have you been to a mechanic or shop? Have you dumped your codes (using the info in a service manual and the ignition key and dashboard method)?
Ed
1994 Ford Explorer Hard starting after it sits. privottfamily Explorer | Explorer Sport Trac 3 05-01-2012 05:14 PM
hard starting dieseltrucktech Cavalier Problem Diagnosis 3 11-08-2010 01:17 PM
Grand Am, Erratice hard starting ChiLLX Grand AM 3 10-23-2010 04:21 PM
2000 3.0 24v hard to start wagon. Tglass Taurus | Taurus Wagon 4 07-07-2009 02:26 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
