Old 10-23-2010, 02:46 PM
ChiLLX's Avatar
ChiLLX ChiLLX is offline
Grand Am, Erratice hard starting
2004 Grand Am. 3.4. About a month ago it started starting hard. Had to crank it several seconds to get it started. Also, it had frequent erratic idling etc. Mechanic said He thought it was Fuel pump because it showed slightly low pressure, but wasn't 100% sure. I had the Fuel pressure regulator replaced in the last year, plus it wasn't spewing fuel out the top like they do when they go bad.
Okay, here is where it gets weird, two days ago, it started acting perfect again. Fired right up every time. Only twice did it take 3 or for turns of the motor before it fired up. I drove it 500 miles yesterday and it ran perfect. It started up fine this morning too. The gas mileage checked out at 30 mpg.
What in the name of freedom could be plaguing my car? I doubt its the fuel pump.
Old 10-23-2010, 03:15 PM
skeeter123 skeeter123 is offline
Re: Grand Am, Erratice hard starting
Have you read the codes? Even if there's no check-engine light, there may still be stored codes. If you don't have a scanner/reader, many of the parts stores (autozone, advanceauto) will read them for you for free. Make sure you write them down. In the mean time, 30 mpg is pretty good; lots of things are working just fine. Maybe it was just some "bad" gas.
Old 10-23-2010, 04:16 PM
ChiLLX's Avatar
At one time there was a "Random Cylinder Misfire". Mechanic said that could be because it wasn't getting enough fuel. I've replaced fuel filter, ran good cleaner through the system, etc. Gotta remember that this has been going on for a month. It isn't bad fuel.
Old 10-23-2010, 04:21 PM
3100 3100 is offline
Banned
try cleaning injectors
1999 Grand Am nanatraci Car Audio 5 06-19-2009 07:00 PM
grand am engine light? confuoco1 Grand AM 1 04-01-2009 04:06 PM
Hard Starting 97 Riveria lavendorj Riviera 3 03-14-2009 08:52 PM
2004 Grand Am bas gas mileage !! ChiLLX Grand AM 8 03-10-2009 08:30 PM
2001 Grand Am SE hard start 00twisters Grand AM 5 07-06-2005 03:48 PM
Tags
2004 , fuel , hard , starting
