Go Back   Automotive Forums Car Chat > Renault > Laguna/Laguna II
Old 01-26-2004, 04:47 AM
sajida sajida is offline
Immobiliser
I've had problems with my immobiliser and this weekend it decided to completly pack in. I was in a car park and the immobilser would not disarm.
Its now been towed to the dealer, and I'm expecting sky high costs of repair. I find it quite strange that there appears to be many people who have experienced similar problems yet Renault have not done anything about this.
Do you think we should do something about this?
Old 04-16-2004, 01:58 PM
davmal3663 davmal3663 is offline
Re: Immobiliser
I have had an Intermittant problem with my 1999 Laguna too. I changed the Batteries in the key etc, I found that by disconnecting the Battery positive lead whilst leaving the key in the ignition for one minute, then reconnecting the lead securely, then removing the key from the ignition and locking the car using the key and leaving the car for 2 hours sorted the problem for me. I have been told that this problem is a common occurance and is either the fault with the Key chip being out of sequence with the immobiliser, or a fault with the recieving ring on the Steering lock. If its the key, Renault quoted me £120 + VAT and a 12 day wait for the new key to be delivered from France, then the key has to be re-coded at the Main Dealer. If its the ring, then its between £40 - £60 plus VAT and a 12 day wait for the ring to be delivered from France then It has to be Syncro'd to your key chip and Immobiliser. Point to note though is that I found it worked for me - it may be you have a different problem and it may not work for you, either way - before considering removal of the Battery lead - make sure you have your stereo code!!! Hope you have some luck.
Old 09-30-2004, 05:02 AM
chumbawumba chumbawumba is offline
Re: Immobiliser
Personally, I think that we need to get a group of us together who are having this problem and as a group, contact trading standards. If this is a known fault through some kind of faulty equipment, Renault should be fixing it at their own expense, not ours. And all those who have had this done should be re-imbursed.
Old 10-11-2004, 02:27 PM
scott587646 scott587646 is offline
Re: Re: Immobiliser
RENAULT DID SOMETHING ABOUT IT ABOUT 3 YRS AGO IF YOU COMPLAINED ABOUT THE KEYS NOT WOKING WHEN IT YOU TOOK THE CAR IN FOR SERVICE THEN THE KEY WOULD HAVE BEEN CHANGED DIDNT TAKE IT TO THE DEALERS FOR SERVICEING ... WHOSE FAULTS THAT RENAULTS
Old 10-30-2004, 08:15 AM
MorganS MorganS is offline
Renault Immobiliser
I have just had a problem with my 1994 Laguna ommobilser locking on. This problem was caused by water getting through the aerial point leaking. Water has gotten onto the receiver printed circuit board which I understand is a common fault with Laguna and Megane models. My fix was to get a replacement second hand receiver board which cost me 10 pounds. I instaled it this morning and it worked. It seems that not many people know where the 4 digit securuity code for the immobilser is stored. Some people think it is in the key fob, others in the receiver circuit board located in the overhead panel. It is in fact located in the ECU under the cars bonnet.
Changing thereceiver circuit board does not lose the code so there is no need to recode anything. This should be your firt option before taking your car to a Renault dealer which will cost you loads of money. Don't forget to get a tube of silicone sealant and seal the aeriel point on the roof of the car as well to prevent further leakin.
Quite a simple fix, takes a couple of minutes. The front panel on the overhead console with the internal lights on just slides forward and reveals this circuit board. Try this before anything else and you may save yourself a lot of money and anguish.
My car ahs been immobilised all this week until I received the replacement circuit board this morning.
Let me know how you get on as I have seen all sorts of theories about getting code numbers and all tha sort of stuff.
Maybe I was just lucky but it would have to be something really big for the ECU to pack up and you you do have an expensive problem.
Old 02-06-2006, 02:33 AM
SHARKY7SHARKY SHARKY7SHARKY is offline
Re: Renault Immobiliser
When Renault cars were sold the buyers should of had a scratch card with a 4 digit number. But Renault have kept these cards from the public. I can only presume it's because then we are at the mercy of Renault. I have just got my number from them after telling them I will prosicute them for holding back this code. Just take your logbook & maybe key code you can found this on the back of the circuit in the key. This 4 digit number will disable the Immobiliser.
Old 02-06-2006, 04:30 AM
When I asked for the code the Renault staff insisted it was illegal for them to provide me with the code!!
Had I owned the vehicle at the time it would've been mine so check your facts before you flame. And check your spelling before you post if you're going to be a clever dick.
Old 02-10-2006, 12:17 PM
seani seani is offline
Re: Immobiliser
I don't know whether is of any interest. I had a problem with my immobiliser: nothing - nothing would get it to start. Then I disconnected the battery for 1 hour - reconnected it and hey presto.
Sean
Old 02-18-2006, 08:49 AM
TazzyK TazzyK is offline
Re: Immobiliser
I'm just curious with this one so bear with me.
A few years ago here in Birmingham, there was an issue with the Immobilisers on most Renaults in that there was a newly built shopping centre in Solihull and if you were in the car park, your immobiliser would not disarm. Not sure how this was rectified (I didn't have a problem with my 1997 Laguna in that car park so I think it probably effected newer cars). The reason I'm saying this is because your car packed up in a car park so maybe there is a similar problem more to do with that location. As crazy as it sounds, it is true about this shopping centre (ironically called Touchwood!)
Old 02-22-2006, 07:09 AM
bluehawk06 bluehawk06 is offline
Re: Immobiliser
you dont wanna go to main dealer lol
i work for blue hawk electronics and we come across with alot of immobaliser probs on the reanult clio/megane & laguna's but what we can do is decode the actual siemens E.C.U (engine control unit) which does away with the immobaliser all together let me know if you need any help
Regards Dennis @ Blue Hawk Electronics
Old 02-22-2006, 07:12 AM
Re: Immobiliser
We are able to Decode the E.C.U control Units which does away with the immabaliser all we need is the part number of the E.C.U and we'll let you know if its possible please contact us on 07773289170 / 07966684240 / 01159539077 mon-fri (9am-5pm)
Old 03-25-2006, 07:34 AM
manandvan manandvan is offline
Re: Immobiliser
hi i,m having the non start problem on a laguna, took it to renault in liverpool and after a two hour deep diagnosis they tell me i need an ecu, key controller and keys plus re-programming, total cost £1050! as if! its a p reg car for god sake, the annoying part is i was told £85 pounds job done in the first place, then the bad attitude of the service reception manager saun voslo, and £180 to retrieve the car with no result! buy another renault?
over my dead body! from what i have gathered and going by another bypass i did the end result of these things is usually one live or one negative to the ecu being controlled on or off, so if anyone knows which wire it is please give us all a break. share share share and stuff renault
Old 04-03-2006, 01:56 PM
John Corps John Corps is offline
Re: Immobiliser
I get a Vocal warning that the imobiliser is not working properly - does this mean that soon I want be able to start the car, if so, Why can't we just rip out the usless imobiliser and fit an after market item does anyone know how to bypass the imobiliser, alarm and central locking controller ?
John
Old 04-04-2006, 11:16 AM
Re: Immobiliser
Is there any way we can rip the bl--dy immobiliser, cetral locking and alarm system out and replace the whole lot with a more usable, non malfunctional system - Does anyone know how best to tackle it?
Old 04-04-2006, 02:23 PM
Re: Immobiliser
How to bypass stock immobiliser? wired Lancer 6 07-11-2012 01:00 AM
Immobiliser TED Laguna/Laguna II 15 11-06-2007 07:07 AM
Peugeot 306 Immobiliser naz 306 1 01-06-2005 04:16 PM
Immobilisers Lors Engineering/ Technical 4 10-17-2002 11:14 AM
BMW Alarm System / Immobiliser Fault LeeMaster 3 Series 0 08-17-2002 11:44 AM
