Go Back   Automotive Forums Car Chat > Mitsubishi > Lancer
Old 04-03-2002, 11:32 AM
wired wired is offline
Question How to bypass stock immobiliser?
Does anyone know how to bypass or disable the stock immobiliser in a '97 Lancer CE? I'm thinking of installing a remote starter myself, and obviously the stock immobiliser would be a problem.
I've figured out the wiring for the ignition keyswitch, but it would be useless if the immobiliser is still active.
I found the plug that connects to the coil around the keyhole, the only thing I measured was a (iirc) 450kHz signal that is active only when the ignition is turned to ON. The engine will crank but won't start if the right key isn't inserted... it controls the fuel pump I guess?
Hope someone can help me.. I'm not trying to steal a car for those cynics out there.
thanks!
Old 11-24-2005, 06:11 PM
phillbo phillbo is offline
Re: How to bypass stock immobiliser?
thanks!
did you find ount how to do this cause its happened to me and i would like a solution .... if you know that is ... thank you
Old 11-25-2005, 02:26 AM
Re: Re: How to bypass stock immobiliser?
The quick and dirty way - cable-tie a spare key near the immobilizer transponder's coil, under the steering column's plastic shell of course. Your insurance co probably wouldn't like it though.. although i suppose if you were putting another immobilizer system in it might be ok.
Old 07-10-2012, 11:57 PM
barrenjoey barrenjoey is offline
Hey Wired,
I am facing the same problem.
Where exactly did you place the original key as I cant seem to find a spot where it will kick the engine over
Old 07-11-2012, 12:15 AM
Originally Posted by barrenjoey View Post
Hey Wired,
Wow, that was over ten years ago!
Hmm.. I can't remember the *exact* spot, but from memory, the transponder coil is inside a white ring that goes around the keyhole. I cable-tied the head of the key to the white ring, which worked.
Old 07-11-2012, 12:59 AM
Thanks Wired
Found the spot and it starts fine
I snapped the original key and got a key cut for peanuts but it wouldnt kick the engine over as the keys are chipped. I called Mitsubishi but what they quoted was absurd. You just saved me $160
Much appreciated
Old 07-11-2012, 01:00 AM
Thanks Wired
Much appreciated
No worries, glad to know it helped someone even ten years later!
How do I bypass the immobiliser on my 1996 Laguna 1.8L RT gwi5727 Laguna/Laguna II 1 07-12-2010 06:30 AM
sudden alternator whine - stock 2003 yukon 4433bryanc Yukon 5 09-22-2009 12:27 PM
EVAP Canister Issues/Possible bypass? sk8injon Engine and Transmission 1 07-25-2009 08:39 AM
bypass air conditioner skycor Cherokee 5 04-02-2009 08:07 PM
how the stock ford block gave up my99cavy Car Videos 1 08-08-2006 01:51 PM
