Old 01-25-2004, 05:43 PM
FathersJeep FathersJeep is offline
cold weather problem?
1997 wrangler. Engine cuts out while driving. Wait a minute or two and it starts again. Problem continues. Temp has dipped here to 40 below. Added drygas but problem continues. Been told to change the fuel filter, and lots of other things. Filter is in the gas tank. What else could cause this problem?
Old 01-25-2004, 07:55 PM
KC Ron Carter KC Ron Carter is offline
Hmm,
If the issue resolves even temporary with no changes it is definite it is electrical.
The next issue is it fuel or spark related.
A spark tester or a sparkplug connected and the case grounded will show if there is spark.
If there is spark I would guess there is a fuel relay overheating due to amperage draw on the fuel pump.
Later,
Old 01-27-2004, 07:53 PM
bm2boats's Avatar
bm2boats bm2boats is offline
Could be the fuel filter but, do you have an odb2 scanner?
It also can be you computer starting to go.
EMS Motto: Your Misery is OUR Pleasure
Old 02-06-2004, 05:55 AM
Re: cold weather problem?
2/04 update
The Jeep went to the Jeep dealer shop. Had diagnostics run and had a tune-up. Replaced the gas filter and regulator. The engine still has a problem here. It did not completely die out, but the power was diminished to the extreme of having to pull over and get the heck off the road.
Old 02-06-2004, 05:59 AM
FathersJeep adds:
Not a mechanical knowing person. odb2 scanner???? Help me on this one.
Rough idle during cold weather start mobzs Sierra 1 03-26-2011 12:00 AM
1990 Accord Cold weather problems? ry2288 Accord/TSX/Accord Hybrid 2 02-06-2007 07:08 PM
Cold weather problem bluevp00 '96-'00 Civic 12 12-05-2005 01:47 AM
Taurus Cold Weather Problem fgross2 Taurus | Taurus Wagon 1 01-24-2005 09:18 PM
cold weather problem!! Help please lakini Metro 1 11-15-2004 09:25 AM
