Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 01-25-2004, 11:57 AM
Roger Tolliver Roger Tolliver is offline
1993 Grand Cherokee-kicked out of overdrive, OD will not work
1993 Grand Cherokee - kicked out of overdrive and cannot get overdrive to work now.
Old 01-28-2004, 11:05 PM
tdenkler tdenkler is offline
re:dropping out of OD
Mine did this for 4 years, but it would drop back in OD. Finally replaced "transmission output shaft sensor" on back of trans extension housing. $15 at o'rielly's or Daps. Autozone doesn't carry it.
Your prob might be different. Might be OD switch itself.
do the following:
1. Turn ign key on,off,on,off,on
2. Count flashes of "check engine" light. It will flash codes with a pause between codes. It will end by flashing 5 times twice. This is end of message code. This Led monitors Engine Control Module(ECM)
3. pull key out, insert again and do same sequence.
4. This time look just below OD switch. An orange LED will flash if you have ANY stored or active TRANSMISSION codes. This Led monitors the Transmission Control Module(TCM) Code 12 on this led indicates the above sensor
Hope this helps,
Tom Denkler
1993 Grand Cherokee disc brakes keep warping and squeking wpatters1229 Grand Cherokee | Grand Cherokee SRT8 15 04-19-2010 10:20 AM
Overdrive button not working mt_100 Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 0 02-23-2010 08:15 PM
91 Dodge 250 cummins cruise and overdrive does not work leecotrell2005 Ram Pickup | Ram SRT10 2 11-12-2008 12:38 AM
Overdrive switch not working paradigmlxi Windstar 1 06-27-2007 08:10 AM
1993 grand cherokee stalls hollow15505 Grand Cherokee | Grand Cherokee SRT8 1 01-01-2004 04:42 PM
