Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 11-09-2008, 09:43 AM
leecotrell2005 leecotrell2005 is offline
91 Dodge 250 cummins cruise and overdrive does not work
my cruise and overdrive does not work. i need help
Old 11-09-2008, 12:43 PM
rockwood84 rockwood84 is offline
Re: 91 Dodge 250 cummins cruise and overdrive does not work
does the horn work? if the horn and cruise control are both not working then the clockspring in the steering column is broken. you should have a torgue convertor relay in the fuse box under the hood. take the t/c relay and swap it with one of the others in the back row all of them should be the same.remember which ones you swapped out and see if the t/c will work now. if so then go get a new relay.
Old 11-12-2008, 12:38 AM
i cant find a fuse box on that truck there is a control box but dont no if there is a relay in it.the overdrive and cruise work when the truck is cold.
