Old 06-26-2007, 09:44 PM
paradigmlxi paradigmlxi is offline
Overdrive switch not working
Hello
When I purchased the van over a year ago the overdrive button worked fine but now when I push the button to turn off the overdrive it doesn't do anything. I have checked all the fuses. Its been like this for a very long time and I have done alot of reading and I have not come accross this problem anywhere. The closet thing I have heard is the wiring runs over or under the steering column and it gets worn until it not longer works on 2002 - explorers. The transmission works fine, except that its alway in overdriver but no blinking light or codes.
2002 Windstar Sport 3.8
Please advise
Thanks
Old 06-27-2007, 08:10 AM
12Ounce 12Ounce is offline
Re: Overdrive switch not working
Make sure that the 10amp fuse in position #14 is good ... this is in the panel near driver's left foot.
I have heard of these switches failing and having to be replaced. It is a normally "open" switch that supplies a 12v signal to terminal 21 of the instrument panel.
