Old 12-27-2001, 01:00 AM
SilverY2KCivic's Avatar
SilverY2KCivic SilverY2KCivic is offline
Cali Guy
Send a message via ICQ to SilverY2KCivic Send a message via AIM to SilverY2KCivic Send a message via Yahoo to SilverY2KCivic
Where to mount amp...?
Got a sweet Infinity amp for X-mas from my cousin and her fiance. I'm gonna attempt to install it myself by this weekend, going to get an amp wiring kit tomorrow. Other than figuring out where I'm gonna conceal the power cables to the amp, I dunno where I should mount it. Wiring the amp up, I'm expecting to be a piece of cake, as I'm pretty good with basic electronaics, and wiring things up. Suggestions I've heard on where to mount it, are on the back of the rear seatback, and then have the sub butted up against it (I have a 2000 Civic coupe by the way), I've also been suggested to just mount the amp directly to my subwoofer box I'm gonna be hooking the amp up to. I would like to install it that way (to help maximize trunk space) but maybe I'm under the wrong assumption here, but if mounted directly to the sub box, wouldn't the vibrations coming from it, not be good for the amp to experience? Ir does it not matter? Also where might you all suggest I mount this bad boy? Thanks.
Oh, and for those remembering "hey, Infinity doesn't make amps anymore..." Your right, well not for the US at least. Yup, the amp I have is a Euro spec amp, model RA7502.
Silver '00 Civic EJ6 Coupe
PureHonda original member since Feb. 2000
D-series revolution For pics of my baby, click here!
All rights reserved... All BITERS served!
"The last time you had THIS much fun driving a car, it cost a quarter, and gyrated in front of the supermarket."
i have yet to see any well done imports around here. most are road toilets driven by some high school punk -Drift
hessemer69 on AIM
Old 12-27-2001, 01:17 AM
xivera's Avatar
xivera xivera is offline
Thumbs up Cool!
If this amp is strictly for your sub, mount it on your sub box given that it is made of MDF. (I forget the thickness...)
I/H/E, I.C.E. & other stuff...
Toni/y v0.2|Nice cars thru my lens...
Your first mod = HELMS MANUAL!!!
Old 12-27-2001, 02:19 AM
Cali Guy
Re: Cool!
Yeah, the box I have is made from "¾ MDF particle board (or is it just called MDF?) Anyways, yeah, it's made out of what it should be, and to the recommeded specs.
hessemer69 on AIM
Old 12-27-2001, 01:10 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Re: Re: Cool!
Particle board is not MDF...
Its only about HALF as dense as MDF and should not be considered a substitute. "Well wood is wood" is not a correct statement. Make sure its REAL MDF... knock on it, the box should NOT sound hollow, it should sound basically like it were a tank. You should hear a THUD rather then the hollow sound. If you built the box yourself, a good way to tell is by how much dust was created. If you used a power saw, you should have more dust and debris then you know what to do with ~ even after just one cut. This is because as you know, MDF is just sawdust and glue under extreme pressures... Particle board would still create a dust, but you shouldnt see nearly as much as MDF is more dense.
BUT, no mounting the amp to the box shouldnt cause any problems. I hate mounting amps to the box for the simple fact it just makes it THAT much easier for a theif to steal everything out of your car. If he sees he has to lean into your car and unscrew the amp from the back seat ~ if the theif feels as if there isnt enough time you would only be out a subwoofer box. Word to the wise, ALWAYS ALWAYS ALWAYS BOLT your subwoofer box to your car...
AF's Official Asshole
RIP AUNIE
Old 12-27-2001, 02:52 PM
kicker1_solo's Avatar
kicker1_solo kicker1_solo is offline
Send a message via AIM to kicker1_solo Send a message via Yahoo to kicker1_solo
I like amps on the back of the seat, here's a picture of how I had mine.
http://briefcase.yahoo.com/bc/anonym...c=bc%26.view=t
2000 BMW 323IT
1954 Ford F100
With every post my penis grows smaller
Yakima Valley Truck Club Yakima Washington
Old 12-27-2001, 03:00 PM
igo4bmx's Avatar
igo4bmx igo4bmx is offline
Banned
Send a message via AIM to igo4bmx
you have a 6th gen coupe?
pull up your carpet in your trunk. look for yous spare and then thearea where the jack hides. between that area is alot of space to mount an amp. it will be hidden and keep space available in your trunk
Old 12-27-2001, 08:33 PM
Cali Guy
Re: Re: Re: Cool!
What I have IS MDF, I wasn't sure if was just called MDF or MDF something else. Anyways, I know wood isn't just wood, I play drums, and so that's one of the first things you just know. Anyways, when thinking about mounting the amp to the box, the theif issue came to mind as well, with me. SO I'm more leaning towards NOT mounting it to the box itse;f. I think the space next to the spare, like mentioned above sounds like a good place to mount it. I'll check it out, and see if the amp will fit there or not.
hessemer69 on AIM
Old 01-01-2002, 07:14 PM
get it in yet? Have any pics yet?
2000 BMW 323IT
1954 Ford F100
Old 01-02-2002, 12:52 PM
Cali Guy
Yup, got it in on Dec. 30th! I ended up mounting it under the trunk floorboard, betweem the spare tire, and the jack, It's out of the way, fits PERFECTLY there, and it's harder to find. I drilled holes in the bottom of the trunk pan, and mounted the board to there, thatr I have the amp mounted to. I'll have pics of it hopefully later tonight. The install itself was rither easy, well all the wiring, and running the cables for it, drilling and mounting the dang mounting board for it, was the hardest part.
hessemer69 on AIM
Old 01-02-2002, 01:34 PM
igo4bmx's Avatar
Banned
yay you took my idea!!
Old 01-02-2002, 04:19 PM
wow, sounds cool. Can't wait for the pictures....
2000 BMW 323IT
1954 Ford F100
Old 01-02-2002, 05:23 PM
Cali Guy
And an excellent one it was, thanks for the suggestion of it.
hessemer69 on AIM
Old 01-03-2002, 02:36 AM
xivera's Avatar
You know what would've been nice?
Maybe... you could've put some light wood (or something... some sorta cover-like-thingie) to surround the amp so it seems recessed... or something...
Old 01-03-2002, 03:20 AM
spy54's Avatar
spy54 spy54 is offline
Send a message via AIM to spy54
so where are the pics man!!
AF Teen Crew
Purehonda.com - may she rest in peace
1996 Chevy C1500, Flowmaster Exhaust, Tinted Windows, 2 Kicker 10" L7 Subs, Eclipse 5v headunit, Alpine V12 Amp
DJM 4/6 drop kit being sold
Full Throttle 9.5 inch lift being installed
1989 CRX si "silver mist"---SOLD---.....Stripped and Wrecked in Compton
corbeau forza 2 seats, DC short shifter, Powerslot slotter rotors, AEM brake pads, Bfgoodridge Stainless steel brake lines, Greddy MX exhaust, AEM Cold Air Intake, Konig Rated-R rims, Kamikazi header
Make an Offer [email protected]
Old 01-03-2002, 07:41 AM
igo4bmx's Avatar
Banned
what i'm gonna do it lay fiberglass to make a mold of the floor.
paint it, mount amps on it in some layout. that area will be covered with a plexiglasscover.
Is it Safe to mount amp to enclsure, permanently? alkemist Car Audio 2 02-08-2007 05:59 PM
Where to mount amps slantyshanty Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 7 11-04-2005 02:44 PM
Mount amp on back of seats? BoNkA10 Audio and Videos 7 08-08-2005 12:45 PM
Mounting Amp On Sub Box ViperJ Car Audio 13 12-19-2004 05:13 PM
Wheres the amp skamxxiii Explorer | Explorer Sport Trac 2 12-31-2003 10:23 AM
