Old 12-18-2004, 05:52 PM
ViperJ's Avatar
ViperJ ViperJ is offline
Send a message via MSN to ViperJ
Mounting Amp On Sub Box
As the title suggests is there anything bad about mounting your amp on top of the sub box. I have a sealed boxed and if I drill the holes for the amp will it still sound fine? Thanks
White 07 STI, Bone stock for now
Old 12-18-2004, 06:17 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: Mounting Amp On Sub Box
makes it easier to steal, that's about it
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 12-18-2004, 06:38 PM
aznxthuggie's Avatar
aznxthuggie aznxthuggie is offline
not a good idea, since its a sealed box, im guna assume its for 1 sub and ur guna screw the amp in in the center of the box? all the "flexing" from the box is going to mess up ur amp sooner or later, just screw the amp in somewhere that isn't on ur box
Old 12-18-2004, 06:43 PM
ViperJ's Avatar
The box is dual 10"s with sealed chambers would that still make the amp flex?
Old 12-18-2004, 07:02 PM
if you mount it right in the center ontop of the dividing piece of wood there willbe less flex but it is NOT a good idea, just mount it somewhere else, lessens the chance of it getting jacked
Old 12-18-2004, 07:06 PM
slammedscion slammedscion is offline
I have 2 12" kicker comp vr's and i have a sealed box w/amp mounted on the back of the box. I have not had any trouble. I have not noticed any difference in the sound from when the amp was mounted on my back seat.
Old 12-18-2004, 08:11 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
If the box flexed that much he should think about bracing and such. You wont have any problems mounting it on top.
Old 12-18-2004, 09:59 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
it shouldn't be a problem ....... just consider it an option - there are plenty of other places to mount the amp as well
Old 12-18-2004, 10:09 PM
RaceMySS_454's Avatar
RaceMySS_454 RaceMySS_454 is offline
Send a message via AIM to RaceMySS_454
I dont like doing it and i never will, i always either mount it on the seat back or somewhere not on the box, because what happens if you need to take the box out one day for some reason, than you have to disconnect everything from the amp also.
Remember....if it has to do with Woman,Wings,or Wheels...theres bound to be trouble.
Old 12-18-2004, 10:21 PM
HighRev87's Avatar
HighRev87 HighRev87 is offline
Banned
Yea really depends on what your doing with it too.
I cant do it, because I want to be able to pull my box before track days or racing, so I dont want to have to worry about disconnecting whole amp.
Old 12-19-2004, 01:58 PM
ViperJ's Avatar
What about vibration will that be a problem? I would think since it is a sealed box it would vibrate more.
Old 12-19-2004, 02:36 PM
Forunn Daberator
Amps are solid state electronics, vibration shouldnt effect them.
Old 12-19-2004, 03:51 PM
sr20de4evr's Avatar
Re: Re: Mounting Amp On Sub Box
yep, and there are more vibrations in the chassis of the car than on the box anyway
'01 Black Sentra SE
'05 Silver WRX STi
Old 12-19-2004, 05:13 PM
bumpinstang77's Avatar
bumpinstang77 bumpinstang77 is offline
Send a message via AIM to bumpinstang77
A correctly built sealed box (right wood thickness and an airtight seal) shouldn't vibrate much and flex at all. Ported boxes are where you really have to watch it, because they are under a LOT more stress.
