Old 01-22-2004, 03:24 PM
msleggz msleggz is offline
Unhappy No turn signal or hazards
I have a 97 Mustang GT V8 and the turn signals just stopped working. My hazard light also stop working. Only the brake light on the spoiler works. I checked the fuse and it wasn't the fuse. I had Firestone to check it out and they told me that they didn't know, but that my bulbs were blown. They wanted to charge me $52.00 for a $4.99 part. So, I went to Pep Boys. They said that the bulbs were fine, but they didn't know why my turn signal and hazard lights were working. I'm going to take it Acme Auto Electric tomorrow, but wanted to see if there is anyone out there who can give me an idea of what I might be looking at. I bought the car brand spankin' new in 1997 so I'm the only owner.
Old 01-22-2004, 03:26 PM
I meant to say that Pep Boys didn't know why my turn signals and hazard lights weren't working (not were working).
Old 01-22-2004, 04:18 PM
BigDanTheMan's Avatar
BigDanTheMan BigDanTheMan is offline
I read and am helpful.
Send a message via AIM to BigDanTheMan
what about the headlights?
hazard lights should never go out in conjunction with another system because they are linked independently. the only reason for them to go with the turn indicators has to be related to the lamps and not the actuators, breakers or switches.
i know i didn't say much here, but just trying to help.
free hypsi87!!
Dan's White Horse
Bring back Melt Crew 002 - 3657 posts can't be wrong!
Old 01-22-2004, 04:40 PM
Re: No turn signal or hazards
The headlights work. Thanks for trying to help.
Old 01-22-2004, 06:16 PM
eillob's Avatar
eillob eillob is offline
That sounds like a relay. Turn signals and hazards use the same relay. It is rare that they go out but they do. I had an F150 with the same problem. Replacing the relay fixed it.
Ported Cobra Intake, Ported & polished Windsor Jr heads, K&N, Vortech s-trim, 90mm Lightining mass air meter, 70mm throttlebody,1.7 roller rockers, BBK Long tube headers, offroad H-pipe, Crane cam, main cap girdle, 40 series flowmaster, 3.73 gears, MSD ignition, CGS subframes, A9L PIH kit, SCT custom burned chip, 42lb injectors, 190lph fuel pump, T rex and fuel pressure regulator, AFCO racing radiator
(If it doesn't scare the Hell out of you it isn't fast enough)
Old 01-22-2004, 06:36 PM
Bronco2 Bronco2 is offline
Turn signals and hazard lites may use the same flasher,but that doesn't explain the brake lites. Not a mustang expert,but all the problems listed seem to go to the turn signal switch.
Old 01-22-2004, 09:04 PM
So assuming that it's the relay....is this expensive to replace?
Old 01-23-2004, 05:41 AM
HiFlow5 0's Avatar
HiFlow5 0 HiFlow5 0 is offline
Stanger
Send a message via AIM to HiFlow5 0
Do the newer stangs use 1 relay for both? I know 87-93's use two different ones. Any yes relays are cheap, usuallu with in a few bucks.
There has to be a short somewhere. Did you do something recently, electrical that could be causing a short?
[size=1]-1950 Ford Custom, flathead V8
-2013 Ford Flex
-1999 Ford F150
Old 01-23-2004, 08:35 AM
I'm not sure if it's 1 relay. When I spoke to someone at Firestone, they told me that it was only 1. However, they also told me that I needed new bulbs and I didn't, so I don't trust what they say.
There hasn't been anything done to the car. I got in it one day to take it to get a tire fixed and didn't have any signals. I thought that maybe they were just acting up again, because previously I would hear it blink really fast, but wouldn't see the light flashing. If I waited a few seconds and tried it again, then it would work. However, this only happened a few times. But, I'm guessing this was a warning that something was about to go out.
Old 01-23-2004, 11:26 AM
HiFlow5 0's Avatar
Stanger
Re: Re: No turn signal or hazards
Humm, I guess it is possiable that is could be this. I know mine went out before I my car, but my brake lights still worked then.
-2013 Ford Flex
-1999 Ford F150
Old 01-23-2004, 01:52 PM
spider7000 spider7000 is offline
Exclamation Re: No turn signal or hazards
[quote=msleggz]I have a 97 Mustang GT V8 and the turn signals just stopped working. My hazard light also stop working. Only the brake light on the spoiler works. I checked the fuse and it wasn't the fuse. [quote]
WoW! That's weird, the very same thing just happened to my girlfriends 98 Mustang LX today. She had a tire blowout on the interstate and turned on the hazard lights while changing to the spare. After she got back in the car she had no turn signal or hazards. The tail lights come on fine with the head lights. Same deal with only the spoiler brake light working also. All fuses look fine too.
So MSLEGGZ, what did the Electrical Shop say it was? Was it the relay?
Old 01-23-2004, 07:05 PM
Talking
Hello Everyone,
Thanks so much for all the replies. I got my Mustang back and everything is working. It turned out to be the turn signal/wiper switch and the turn signal flasher relay. It cost me $261.00.
Old 01-23-2004, 07:33 PM
I think I win this one on diagnostics. Not trying to give myself a "attaboy"-but when your trying to diagnose a multiple problem failure you need to find the point where all the systems come together.In this case,all the symtoms pointed to theT/S switch.
Old 01-23-2004, 10:24 PM
eillob's Avatar
A excuse me but it was not just the T/S switch it was also the relay like I mentioned. NO relay no flash. Just wanted to throw that in there while you were sitting there patting yourself on the back.
Old 01-24-2004, 08:09 AM
HiFlow5 0's Avatar
Stanger
Well I did second your guess!
eillob, the only reason the relay went is because there was a short from the mulit-function switch. LOL
-2013 Ford Flex
-1999 Ford F150
Turn Signals/Hazard Warning Light/Trailer Brake Lights jwsulliv Sierra 3 07-24-2004 08:19 PM
Turn signal/hazard prob bluegothgurl Accord/TSX/Accord Hybrid 1 04-27-2004 08:11 AM
turn signals/hazard not working-help! jc83 Grand Prix 3 04-03-2004 08:24 PM
92 Taurus Turn signal,Hazard problem Loggerhead Taurus | Taurus Wagon 0 03-01-2004 06:36 PM
