Old 01-22-2004, 02:59 PM
bobsmith23 bobsmith23 is offline
Send a message via AIM to bobsmith23
Question 1997 Metro not spraying fuel from the TB
This is a stumper. My friends metro will not start for anything. It turns over just fine. When I spray starting fluid into the intake, it starts right up. When it runs out of starting fluid it dies. Obviusly it is a fuel delivery problem. So, I cracked the banjo bolt that attached the fuel supply line to the throttle body and turn the key to run position. It sprays fuel everywhere. I cannot see fuel coming out of the injector when it is being turned over. I checked the resistance of the injector. It was about 5 ohms. I do not know if that is good or bad cause I have no specifications. I also get no readable signal to the injector when I crank it over. I check the injector resistor I cannot remeber what it reads, but it has continuity. I checked all the wiring, it seems tight and undamaged. I am going to try to find some information on retriving trouble codes from the computer. I am not sure if there are any, as I cannot get the engine to a permanent runnging state to find out. So, if anyone knows anything, every bit helps. Thanks.
Rob
Old 01-23-2004, 12:57 AM
More information on the problem
I checked the engine computer for codes. All I got was Air Intake Temp readings out of range. It turns out someone clipped the wiring harness connector off. So I rigged it the harness into the sensor for a temp fix until I can get to the wrecking yard to get another connetor. I reset the trouble codes and went for another reading. No problems. I am banging my head on the wall on this one. Has anyone had fuel injectors so badly clogged they would not spray fuel. Perhaps the problem is an intermitent wiring issue. I have narrowed it down, but I do not want to tear into the wiring. Another possiblity, does anyone have one of those security systems that requires the key chain device be passed by it to allow the engine to start? If so, how intimately is it tied into the engine system? Thanks again. Any input would be greatly appreciated.
Robert
Old 01-28-2004, 10:08 AM
codboy codboy is offline
Re: 1997 Metro will not start
had same type of problem had to replace trottle body
Old 01-29-2004, 12:17 PM
Thanks for the tip, I will look deeper into the thottlebody.
Old 01-29-2004, 04:59 PM
geozukigti geozukigti is offline
A new intake at the wreckers should be pretty cheap, and easy to put on
1997 Saturn SL not starting DebbiR SC/SL/SW 19 07-17-2016 08:25 PM
1997 540i will not start! jrod540i 5 Series 2 10-13-2005 01:23 PM
metro will not start GaryDG Metro 6 04-28-2004 10:13 AM
94 Metro Will not Start HELP!! irishguy1978 Metro 13 04-01-2004 04:15 PM
1997 Tahoe will not start bigjul45 C/K 2 11-18-2003 05:05 PM
