Old 04-26-2004, 08:19 PM
GaryDG GaryDG is offline
metro will not start
My 92 metro will not start. It has spark to the plugs and is getting gas. It will turn over but will not fire. Any suggestions??
Old 04-27-2004, 02:05 AM
barteldt barteldt is offline
Send a message via AIM to barteldt Send a message via Yahoo to barteldt
Re: metro will not start
timing belt
Old 04-27-2004, 10:51 AM
geojim geojim is offline
Remove the distributor cap with wires and hang it up out of the way. Have some one crank the engine while you look at the rotor inside the distributor. If the rotor does not turn, your timing belt is broken. Jim
Old 04-27-2004, 10:55 AM
geozukigti geozukigti is offline
If he's getting spark to the plugs, his timing belt should be ok, because the distributor is doin it's job. Sounds more on the lines of the timing is off, or you aren't getting enough fuel pressure. If you have a timing light, make sure your timing is ok. Your belt may have skipped a tooth, or is stripping.
Old 04-27-2004, 05:53 PM
rruddfan21 rruddfan21 is offline
i'm surprised no one has pointed to the starter
Old 04-27-2004, 06:07 PM
Since he said it "will turn over", I would think the starter is working. Jim
Old 04-28-2004, 10:13 AM
OOPS!! my bad i didn't read slow enough i guess LOL i feel dumb
