I'm considering buying a fuel pressure regulator for my 95 acura integra ls. So far i have a AEM intake, OBX headers and tanabe super medallion exhuast. I've considered either buying a B&M fpr or a AEM fpr. Which is easier to install or which is better quality?
Re: which fpr is better?
I'd go with AEM. |
I would go with the B&M. It is cheaper and more simplistic in its construction. It is easily installed and tuned aswell. |
what good does an FPR do? on a mildly modified or even stock car.
you need one to make sure you have enough fuel to achieve the right air/fuel ratio. there is already a stock one on your car, but its set to a fixed pressure that may be too low to work with your newly increased air flow such as intake/exhaust/headers. so if you set it at the right pressure, it should help out.
has any one had experience installing one? if so is it easy?
Re: Re: which fpr is better?
Good Luck if...
^ that is you make the decision to go through with the purchase and installation.
ya i think i will get the B&M fpr, thanks
but have you ever had experience with the B&M fuel pressure gauge? if so is that easy to install?
