Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-20-2004, 11:16 PM
dschwartz46 dschwartz46 is offline
1998 Camry LE - Stock Alarm
My 1998 Camry has a stock alarm that was installed by the dealer. Initially, it was programmed to not "chirp" when it is set, only flash the lights. I would like to somehow reverse this so I can get the chirp or short horn blast. Is there any way to do this without taking it in to a shop or back to the dealership?
Thanks.
Old 01-21-2004, 06:49 AM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: 1998 Camry LE - Stock Alarm
Thanks.
Probably have to make a trip to dealer
Old 01-21-2004, 02:45 PM
salempastor salempastor is offline
Re: Re: 1998 Camry LE - Stock Alarm
I have a 97 with a VIP RS 3000--instructions say to turn it off: insert the key in the ingnition and turn it to "ON" not "ACC". Using 1 remont, press and hold BOTH buttons at the same time for over 2 seconds, until the Status Monitor LED turns on. You must perform the next steps in 30 seconds. Press and release the bottom REMOTE CONTROL BUTTON once. (it chirps once). Turn the ignition switch to the "lock" position. (it chirps 3 times) hope works! Mark
Old 01-21-2004, 02:48 PM
See the above reply, (on the last part of the instruction) only press and release the bottom remote control button twice instead of once.Sorry--Mark
Old 01-21-2004, 06:21 PM
Thanks!
Mark, thanks a million! It worked just like you said! I thought I was going to have to pay the dealer $60 to do what took me ten seconds!
Thanks again,
Daniel
Old 01-21-2004, 06:40 PM
Do you have a manual for the alarm? I was wondering if I could get a short blast of the horn when I set it, in adition or instead of the chirp.
Thanks.
98 Camry engine replacement. posiman Camry/Camry Hybrid/Vista 6 02-01-2010 01:00 AM
'98 Camry Stock Alarm - Glass-Break Sensor dschwartz46 Camry/Camry Hybrid/Vista 8 03-04-2004 10:12 AM
1998 Camry Le....alarm Question... TRUCO_ONE Camry/Camry Hybrid/Vista 0 07-24-2003 12:00 PM
Stock alarm and turbo timers 95_GSX Off-Topic 4 07-21-2003 11:49 PM
P10 stock alarm question MoReace Audio/Security 0 11-10-2001 01:30 PM
