Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 01-25-2010, 09:36 PM
posiman's Avatar
posiman posiman is offline
Question 98 Camry engine replacement.
I have a 98 Toyota camry 2.2L and i am looking to upgrade from a stock engine. what is the biggest posible engine i can put in it. Also i was told that a 2jz swap could fit perfectly with the chasis and i could easily change the rearend to RWD all i would like to know if this is true. If so i know that this is the biggest strongest engine possible. thanks
Old 01-26-2010, 11:27 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 98 Camry engine replacement.
I think someone has been telling you stories. An inline-6 will be much longer (and I believe taller) than any engine installed by Toyota and will never fit in as a rear-wheel drive engine. In order to use this engine, you would have to extend the front clip at least a foot to provide clearance. There is no way it will fit as a transverse front-wheel drive engine. There were all-wheel drive Camrys available, but none with a inline 6.
Anything is possible, but you would be creating a new car, not modifying a Camry...
The best route for you would be buying a V6 Camry and making due with the available mods.
Someone please correct me if I'm wrong.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 01-26-2010, 11:18 PM
posiman's Avatar
the thing is i don't want to put in a lousy v6 i would like to put something that is available to a strong turbo. with a v-6 engine it will only be able to withstand 11PSI from a turbo unless it was boared out than it can take 15PSI but i want to use something that can withstand a 32-36PSI turbo.
Old 01-27-2010, 07:43 AM
Brian R.'s Avatar
Resident Chemist
I think you need to find a used Supra or SC-300.
Old 01-27-2010, 09:47 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Supercharger kits are available for the Camry (Solara) V6 via Toyota's TRD division. If you can find a junked Solara from that year, you can do the engine/tranny/ECM swap then bolt on the blower. You even get a warranty on it. But granted, it puts out a tepid 4 psi boost. Any engine you want to withstand the boost you're looking for will need serious upgrading.
It will save you plenty of headache and money trying to shoehorn an I-6 longitudinally AND find room under the unibody for the drive train for a RWD....you'd need to cut the floorboard and center console to accommodate the tunnel.
If you really want a fast blown sedan, ditch the Camry. There are easier cars out there to mod.
[EDIT] Turbos have been fitted to 4-banger Camrys, just no kits available through TRD. They run ~6-7 psi boost...again probably to keep from having to upgrade engine components.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 01-31-2010, 06:30 PM
posiman's Avatar
i have recently discovered that they did not make any v-6 camry's that are 5speed so how else could i get a v-6 5speed does the salora have one? Also i did think about getting a better car to tune out but the thing is that honda's are too overpopulated and its rare to find an eclipse around here also i would love to do it to a car that no one would think of seeing.
Old 02-01-2010, 01:00 AM
Brian R.'s Avatar
Resident Chemist
Consider an SC-300. They are pretty easy to ignore...
Tags
1998 , biggest , camry , engine , swap
