Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-20-2004, 10:10 PM
Gotrice_San Gotrice_San is offline
Send a message via AIM to Gotrice_San
2 Stage NITROUS
Hey has anyone tried this yet?
Put the usual wet setup but add another "stage" to it.
From the bottle spit the line into two (via Y ot T joint) and run one for the normal wet setup. Then for the other one use it as a dry setup. The dry setup would be more the like the Sneeky Pete system, so just jetted pure N2O into the intake. I would say 30-50HP dry shot.
The wet one is for WOT and the dry is manully activated when needed for last boost to kill your enemy.
Good, bad, ugly?
Old 01-21-2004, 12:58 PM
tsugsr tsugsr is offline
Re: 2 Stage NITROUS
you better have alot of money, you would be buying a new engine every race.
Old 01-21-2004, 02:02 PM
96Civ's Avatar
96Civ 96Civ is offline
PURE NITROUS!!!
New engine indeed.
Old 01-21-2004, 07:15 PM
Re: 2 Stage NITROUS
No no...see the word jetted? When I ment pure N20 I ment just n2o and no fuel....a true dry system...plus its only 30-50HP
Old 01-21-2004, 07:51 PM
96Civ's Avatar
Hehe, I thought you ment a 50 Shot of n2o DRY! Not a 50hp shot... I was confused.
Old 01-21-2004, 10:41 PM
Re: 2 Stage NITROUS
Whats the difference? 50 shot means 50HP right? The jet number means the amount of HP...right?
Old 01-22-2004, 02:37 AM
jajimo's Avatar
jajimo jajimo is offline
Re: 2 Stage NITROUS
Umm, you're going to inject just nitrous oxide into your engine and detonate it with spark plugs? No fuel? Nothing?
Old 01-22-2004, 05:27 PM
Ok, you guys arent getting it....
The engine is runing....and you are racing some Biznatch....
You active the Nitrous system to kick some ass...but he's got more then you so you hit the second stage for the last extra boost to win....get it?
You are running a wet system but split the lines from the bottle so there is two from the bottle now.
Then you route one of the lines to your normal wet setup.
The second one goes to a nozzle with like a 30-40hp shot. But the only difference is that you only have the Nitrous in the second stage and no more fuel added.
You will need another silenoid (cant spell) and a stwich somewhere you can manully active it with. And a dry nozzle with a low horsepwer jet.
Any opinions? (if you get it)
Old 01-22-2004, 05:33 PM
PunkAlex's Avatar
PunkAlex PunkAlex is offline
Send a message via AIM to PunkAlex
I can understand what you are saying....pro drag racers use 2 and 3 stage nitrous all the time! but theyre setup is a bit different. Youre idea is cool, but does have some flaws. Youre engine has to be pretty well built in order to handle dual shots. You also (even with a small shot of dry) might have lean problems when you hit it, so tuning would definately be needed.
I'm Alex. A cookie to whoever guesses what car I'll get!
I tend to hate people....expecially liberals...
This is my temporary racecar-the two liter beast itself, the 87 camry:
Old 01-22-2004, 09:59 PM
A little lean wont kill....plus, it will only be for a short time.
And thanks for getting it....LOL
BTW, how do they do it?
Old 01-23-2004, 04:11 PM
PunkAlex's Avatar
They generally use a fogger system with multiple nitrous ports. Pro's are almost always computer controlled and at certain points in the powerband it releases different sized shots of nitrous, for example it may let loose a 200 shot at 3000rpms and then a 300 shot at 5000rpms (these are short blasts btw)..It just steps up at certain rpm points. But all computer controlled.
Stage 1 stage 2 stage 3 parts? Eagalicious Off-Topic 2 07-21-2005 11:00 PM
Nitrous Oxide Groupbuy/Sale: ZEX, NX Nitrous Express, NOS, Venom, TNT, Nitrous Works ImportCarPartPlus Group Buy Market 0 06-15-2004 11:48 AM
Nitrous Oxide Groupbuy/Sale: ZEX, NX Nitrous Express, NOS, Venom, TNT, Nitrous Works ImportCarPartPlus Group Buy Market 0 06-14-2004 08:54 PM
Dual Stage Nitrous System! mfmark5007 Forced Induction 4 10-22-2003 10:02 PM
Which Nitrous kit on the Civic, ZEX or Nitrous Express?? UMIPerformance '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 09-19-2003 07:47 PM
