Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 10-21-2003, 05:32 PM
mfmark5007 mfmark5007 is offline
Dual Stage Nitrous System!
What do they mean when they say a dual stage nitrous system???
How does it work??
How is it different??
(anyone know of a good site that describes it??)
Old 10-22-2003, 03:30 PM
Myjunkistight Myjunkistight is offline
Re: Dual Stage Nitrous System!
I think a dual stage nitrous system is a system that activates a lower jet right off the start (in drag racing) so that they can keep traction, and then at a certain point shifts to a higher jet. I think.
ZC Crx ready for the HMT kit.
Old 10-22-2003, 03:55 PM
Mrock Mrock is offline
Send a message via AIM to Mrock
I think Jegs has dual stage setups for sale..just in case you're actually considering one...
ZC powered '91 CRX...JE 10:1 pistons, Crower rods, Bullfrog cams, Throttle body bored by Gude, Port and polished head, AEM adjustable cam gears, 340cc injectors, MSD SCI ignition, Cold air intake, clutchmaster stage 2 clutch, aluminum flywheel/heavy duty pressure plate, zex nitrous kit.
Waiting to arrive (and install, to get this baby running!)
Walbro fuel pump, PWR radiator, PM7 ECU
Look out, I can run 17's allllll day.
Old 10-22-2003, 07:03 PM
93weed_eater's Avatar
93weed_eater 93weed_eater is offline
Send a message via AIM to 93weed_eater
hhhmmm i thought that was that fast and furry crap where they hit the nos again only its a different button for more boost.
Old 10-22-2003, 10:02 PM
whtteg's Avatar
whtteg whtteg is offline
Send a message via AIM to whtteg
Myjunkistightn is on the right track here. It is two nitrous setups one is a smaller shot and is used until the car is moving fast enough to keep traction and then the 2nd one is used after speed is up enough where traction will not be an issue, usually they are use on cars with upwards of 300hp and more. There is a guy around here who has a integra LS and he has a dual stage kit on it running open solenoids on both kits he ran a 12.8 coasting the last 100' or so because the engine blew but he has been doing it for around 4-5 yrs now I think.
