Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 01-19-2004, 09:43 PM
starkravingmad starkravingmad is offline
Question traction assist needs to go!
pls help! i want to turn off the traction assist on my 93 marquis. has anyone been able to do it? maybe just disconecting a wire to the comp? chip? hammer? can't take it anymore either the T/A goes or the car does pls help!
Old 01-22-2004, 07:42 PM
MercCougarXR7's Avatar
MercCougarXR7 MercCougarXR7 is offline
Re: traction assist needs to go!
Pull your ABS fuses under the hood (2 big black square ones).
You're ABS won't work anymore, but you'll be able to do big smokey burnouts.
But don't blame me when you wind up in a plowed field on a rainy night at 3:00am when you had to panick stop and the ABS won't work. That sucked.
2000 LS8 Sport, 1992 XR7 5.0 HO
Old 02-17-2004, 01:26 PM
clydes270 clydes270 is offline
Registered User
Send a message via AIM to clydes270
Having the assist helps to pass emissions. They can't be tested on a dynamo. So, idle tests apply.
Old 04-05-2004, 12:54 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
I had a 93 Ford Crown Vic with the traction control, hated it. But the ABS saved my tookass a couple times. I'd swap the t/c in a second for a good limited slip diff!!
Old 02-18-2005, 11:51 AM
94merc 94merc is offline
I have a 94 grand marquis is there no way to put the limited slip in the rear and diable just the traction assist but yet keep the abs functional? also how many of these came with dual exhaust and where the stock gear ratio's ? thanks
traction assist problem. sportin83 Silverado 1 06-06-2006 09:43 PM
Traction Assist option on 94 Cougars 3Racefan Cougar 4 07-03-2005 08:53 PM
02 Tahoe ABS & Traction Assist Light ON kile44p Tahoe 1 11-07-2004 10:37 AM
2001 Tahoe Traction Assist jthomp23777 C/K 1 08-24-2004 02:58 PM
Traction Assist. ??? v_cruz Yukon 0 06-24-2004 02:08 PM
