Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 01-19-2004, 10:29 PM
R34NJ R34NJ is offline
99' Quest won't start after pushing the button
Hi,
My 99' Quest won't start after I pushed the button stored behind the driver side kick panel. It's a black switch with red light on one end and the button on the other end. It was floating inside and not attached to anything but the several wire. I took off the kick panel to install remote starter and found this button.
It seems this is a switch to disengage the starter for safety reason, but I don't know how to reset it. If anyone know how to reset it, please let me know. I promise I won't push any strange button anymore.
Thanks in advance
Old 01-20-2004, 07:49 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Re: 99' Quest won't start after pushing the button
Originally Posted by R34NJ
Hi,
Thanks in advance
You sure that's not the fuel safety switch? Check the owner's manual.
Old 01-20-2004, 09:18 PM
Re: Re: 99' Quest won't start after pushing the button
Thanks for the message.
The fuel switch is located in the different location, so that's not it. Maybe I should have more specific. It's not that car does not start, but the starter does not crank.
I checked the wires from the switch and they are going into the small black box that seems like a factory installed security system. I checked the battery, and fuses and they are all fine.
Any idea?
Old 01-21-2004, 07:53 AM
Re: Re: Re: 99' Quest won't start after pushing the button
Any idea?
If you have keyless entry, press unlock with the remote first then try to start it. Other than that, I have no idea. Could be some sort of dealer installed device.
Please Help! 95 3.4 Won't Start No Spark elvisnut F-Body Problem Diagnosis 9 04-09-2009 04:20 PM
1998 Nissan Pathfinder Won't Start after replacing the battery aepcars Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 1 03-30-2008 05:38 PM
99 grand caravan sport, won't start after havging the "gauges" problem fixed 99dodgegrsport Caravan | Voyager 2 04-19-2006 06:09 PM
4x4 does not engage when I push the button MyOldJimmy Jimmy 12 02-01-2005 08:39 PM
99' Quest won't start after pushing the button R34NJ Quest | Presage | Serena 0 01-19-2004 10:32 PM
