Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 01-24-2005, 01:41 PM
MyOldJimmy MyOldJimmy is offline
Unhappy 4x4 does not engage when I push the button
I got my truck back from the shop. I found when I pushed the 4hi shift on the fly, nothing happens. The only way to make it shift, I have to put it in nutral then, the light blinks a few times and goes back to 2hi. In order to go to 4low, I do the normal, stop, nutral, and shift.
Can anyone help shed some light on this for me? Please and Thank You.
AJ
Old 01-24-2005, 04:26 PM
Sputnik13 Sputnik13 is offline
Don't know if this is the case with your vehicle but I recently took my car in to the dealer to have my 4wd diagnosed as it wasn't going in to 4wd at all (hi/lo). They said the problem was with the vacuum lines or something and I got it fixed for around $150 at the dealer.
Old 01-25-2005, 07:22 PM
Re: 4x4 does not engage when I push the button
Thank you. I was thinking the same thing. I hope you're right. I am going to reset my computer first. If that dose not work I will replace the vacuum line.
Thank you,
A.J.
Old 01-25-2005, 07:30 PM
I reset the computer and the 4x4 works just as before.
Old 01-26-2005, 02:37 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
You mean it works properly now?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 01-26-2005, 07:03 PM
Re: Re: 4x4 does not engage when I push the button
Yes. It works just like it always did.
Old 01-29-2005, 09:03 AM
Bluetick1955 Bluetick1955 is offline
Re: Re: Re: 4x4 does not engage when I push the button
HI, JUST THE INFO I WAS LOOKING FOR. HOW DID YOU RESET COMPUTER?
Old 01-29-2005, 03:59 PM
BlazerLT's Avatar
AF -Advisor
Remove the negative cable from the battery for half an hour.
Old 01-30-2005, 07:14 AM
What he said. Thank you BlazerLT. I have been away from my PC for a while
Old 01-30-2005, 01:51 PM
BlazerLT's Avatar
AF -Advisor
It worked?
Old 01-31-2005, 05:11 AM
It did work for me. However, I did some investigation and found that while my truck was in the shop for brake service, they had blown a fuse some how. I know this because I found the fuse puller on the floor. I assume it had sent a false code to the computer and caused the 4x4 not to react. Love that computer....
Thanks
AJ
Old 01-31-2005, 02:08 PM
BlazerLT's Avatar
AF -Advisor
That is not cool, blown a fuse and never told you?
It is really getting sad when mechanics are starting to get more and more sneaky.
Old 02-01-2005, 07:39 PM
xokayxo's Avatar
xokayxo xokayxo is offline
Send a message via AIM to xokayxo
yeah... and they're usually men.
