Go Back   Automotive Forums Car Chat > Cars in General > Legal Issues > Traffic Violations - U.S. only
Traffic Violations - U.S. only Discuss anything conerning speeding tickets and other traffic violations in the US.
Old 01-19-2004, 08:56 AM
xSILENTx xSILENTx is offline
Send a message via AIM to xSILENTx
NO cat. converter laws
I took out my converter awhile back and was just wondering what kind of price i could be looking at paying if i get caught. I live in PA . I'll put it back in if its to illegal.
Old 01-25-2004, 08:03 PM
quaddriver quaddriver is offline
Send a message via AIM to quaddriver Send a message via MSN to quaddriver Send a message via Yahoo to quaddriver
Re: NO cat. converter laws
as of the first of this year, PA, regardless of county, now visually inspects that the CAT is there, as well as EVAP, EGR and AIR systems.
So you will fail the next insp and there is no spending limit to get back into compliance. Todays high flow replacement cats do not hinder performance.
Old 02-21-2004, 08:29 PM
Jlink2004 Jlink2004 is offline
if you get caught you will have to bring your car in and have it tested on an IM240 and if you put your cat back on before that youll be fine you get three chances to get into compliance or theyll take your car. Trust me Im an Automotive Technician.
Old 03-12-2004, 11:09 AM
jdrumstik's Avatar
jdrumstik jdrumstik is offline
You could do it monster garage style, go find a clean looking cat at a junkyard, gut it, weld it, have the weld face the car, not the road. Then when you smog test comes up put the stock cat in.
Old 03-13-2004, 10:16 AM
flyingskwerrl's Avatar
flyingskwerrl flyingskwerrl is offline
Banned
Jd's got the right idea. Go to a garage and find an old one or one that matches yours. Gut it. Find some exhaust pipe the same legth of the cat. Make sure its about an 8'th of an inch from either flange.Have your welder put a nice bead on it and grind it down nice and flush. There you go. Works like a charm. You dont want to just gut a cat and put it on. Not only does it sound like a coffee can but it actualy make you loose hp. Hope this helps!
Old 03-15-2004, 03:15 PM
jdrumstik's Avatar
run the pipe through the cat right?
Old 03-20-2004, 07:17 PM
RocketDSM RocketDSM is offline
Yes. But you need to do a good job or connecting the two ends or you can easily end up making as much turbulence as the car did in the first place. Best bet is to half the old one and lay the pipe in it and reweld. Or buy a high flow cat, they aren't too expensive anymore.
Old 03-29-2004, 10:12 PM
Webslinger60 Webslinger60 is offline
I tried an empty cat (that was damaged from a backfire).
I did notice a little (just a little) boost in HP & MPG (BTW-it WAS a hi-flow cat to begin with). But it also echoed the exhaust note & sounded terrible.
Welding a pipe through, would cut the sound, but I bet you will NOT find a shop willing to do this, unless you're a personal friend of the owner.
It's not worth the trouble or legal risk. A hi-flow cat is your best bet.
I had a discussion on another board about this. Removing the cat is
illegal, federally (all 50 states) The fine is $2500. Usually levied toward
auto business, but could be charged against a private owner too.
But the powers-that-be would actually have to remove the cat & look through it, to have indictable evidence. It's not likely. A private owner could also plausibly, plead igorance & just install a cat to comply.
About these "fail 3 times & loose your car" states. I dont know about that. Does anyone actually know of a person who's car was confiscated
for failing emissions? (im not talking about a semi race car with numerous
equip & safety violations). NJ was gonna try that and the public screamed! So they backed-off.
Anyway, how are they gonna take your car? At gunpoint? I would just get in & drive away. I would rather get a lawyer & fight the addtional charge of refusing, rather than just surrender my car on the spot??
Random Technologies Cat converter for P10 WRAITH Engine 0 07-18-2002 03:36 PM
which cat converter do i buy, match engine or chassis? PoweredByRice_619 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 04-08-2002 07:07 PM
Cat. Converter Deterioration JasonAccord98LX Engineering/ Technical 13 02-26-2002 07:09 PM
Help! I tried to take out my cat converter on my 01 lude, but it has sensors! Lingerie_Ripper Prelude 2 02-01-2002 01:53 PM
