Old 01-19-2004, 07:23 AM
mdb25 mdb25 is offline
98 Grand Am GT hesitates under heavy acceleration
I have a 98 GA GT (2.4L, 5 speed) which is having occasional problems with heavy acceleration. This problem occurs rarely and sporadically. Has happened when the car is cold and warm. The car hesitates when placed under heavy acceleration. If I let up on the gas pedal, it's works fine. It's only when I really try to accelerate quickly that it has problems. There are no warning lights or check engine lights on. I've changed the fuel filter, plugs, and air filter on a regular basis. When acceleration is light, the car is perfect. My own experience makes me think that it's either a bad ignition module or a bad fuel pump. Anyone else had this problem? Any advice would be greatly appreciated.
Old 01-19-2004, 08:13 PM
urweak urweak is offline
Banned
Send a message via AIM to urweak
Re: 98 Grand Am GT hesitates under heavy acceleration
yea my car does this. mostly when i just start the car. Its your CTS (coolant temp sensor) replace that and it should go away.
www.gmperformancetuning.com
Old 01-29-2004, 03:06 PM
Hey thanks for the advice. I was a little hesitant to start replacing any sensors because I didn't have a check engine light on, but I changed that CTS sensor because it was only $7. Car has been running great for about 600 miles. No more hesitation.
Old 01-31-2004, 08:55 AM
Gary300 Gary300 is offline
Send a message via AIM to Gary300 Send a message via Yahoo to Gary300
I thought the Grand Am's were supposed to do that. When my car is at idle in park I will rev the engine and it goes to 5 RPM's then it sounds like it's starting to bog out. Or if I'm spinning tire in snow it will do it then, too.
My mechanic said (My uncle), that does that so people don't blow their engine. it's like like a security for the engine.
Is that true or was he joking with me?
Old 01-31-2004, 09:39 AM
justin0419 justin0419 is offline
Gary,
I've got a '96 GA GT with a 3.1L V-6. It has a rev-limiter. When my car is in park, it will only rev up to about 4K RPM before the limiter kicks in. Then it fluctuates if I keep the pedal on the floor. So your uncle wasn't pulling your chain. The spinning in snow thing is probably your traction control kicking in.
Old 01-31-2004, 10:29 AM
Thanks for the reply,
I always wondered about that..cause when I'm spinning in the snow..it does the same thing as if I were in park at full throttle, it feels like I'm losing power.
Gary
Originally Posted by justin0419
Gary,
95 LeSabre Hesitates During Heavy Acceleration CarDude225 LeSabre 2 05-17-2007 08:30 PM
Tinging noise under heavy acceleration putertopia Grand Marquis 7 11-24-2005 12:41 AM
92 SSEI bogs down under heavy acceleration dmnkid Bonneville 1 10-01-2005 10:42 PM
Pinging or Timing Chain Rattling under Heavy Acceleration, Please help me.. solaris=amazing Engineering/ Technical 7 07-03-2004 09:27 PM
hesitation under heavy acceleration kobie1 626/Capella/Capella Wagon 0 06-21-2004 09:52 PM
