Go Back   Automotive Forums Car Chat > Honda > CL | Inspire | Saber | TL
Old 01-18-2004, 08:33 PM
SupraBo SupraBo is offline
Send a message via AIM to SupraBo Send a message via MSN to SupraBo Send a message via Yahoo to SupraBo
Arrow problems
I can't find out whats wrong with my remote keyless entry... these are some comman problems...
Trouble Spots
Gauges: The tachometer needle fluctuates, and the "D4" light blinks due to a problem with the transmission control module (TCM) that is, in most cases, replaced under goodwill. (1997)
Mirrors: Fluttering or whistling noises come from the outside mirrors due to a faulty run channel that must be replaced. (1997)
Seat: The power seat may not move properly because the synchronizer cable comes loose from the seat. (1997)
Seat: The front passenger seat may not move forward when the access lever is pulled because the rear seat access cable comes loose. (1997)
Speedometer: The indicated speed (on the speedometer) and true speed may not jibe. Speedometers were being replaced under extended warranty. (1997)
Sunroof/moonroof: The moonroof seal may pop out when the roof is opened. (1997)
Windows: The windows rattle when partially open due to a problem with the guide pin and rear channel. (1997-98)
point is, i can't find anything on how to fix it. the battery is good and i have tried programing it 4 times. can't figure it out
please help
Problems Problems Problems... HondaChili MR2/MR-S 2 06-22-2004 03:12 PM
problems problems and more problems tacoma man Monte Carlo 1 05-12-2004 09:57 PM
ignition problem, transmission problem, you name it problem 1hotmama Sable 1 04-20-2004 12:17 PM
Problems, Problems and more.... Problems. Killa_CRX '88 - '91 Civic | CRX | Wagon | Shuttlee 6 03-02-2004 03:01 PM
Problems, Problems and More PROBLEMS!!!! 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 15 06-21-2003 11:59 AM
