Go Back   Automotive Forums Car Chat > Engineering/ Technical > Forced Induction
Forced Induction Discuss topics relating to turbochargers, superchargers, and nitrous oxide systems.
Old 01-17-2004, 08:26 PM
motormike40 motormike40 is offline
Send a message via AIM to motormike40
do u need turbo software?
If u make a kit for ur car do u need any enhancing software, or can u just bolt one on and go? i heard if u get a FMU u wont need anything else like fuel or for ur ECU. if u bolt a turbo on will it throw ur ECU for a loop without any software for the car.
Old 01-18-2004, 01:16 AM
KC Ron Carter KC Ron Carter is offline
Hmm,
I can think of no EFI, Electronic Fuel Injection, engine that can not handle 6 psi with no modifications. And with normal format that is good for a 100 hp bump.
For 6 psi to 9 psi you will need added fuel, RRFPR, Rising Rate Fuel Pressure Regulator.
For 9 psi to 12 psi you will need ignition timing modification, the added ECU ot timing control.
For anything over 12 psi you will need added internal modifications and modified fuel and timing control monitored by a wideband o2 sensor.
Later,
Automotive Maintenance Software ascetik Engineering/ Technical 0 06-30-2010 09:02 PM
Computer software on my Z-3 scrambled - why? fabricatortim Z3 0 09-01-2009 08:21 PM
Need Turbo super_san_hbka24 General Discussion 3 07-17-2003 10:38 AM
Need turbo help! GTRZ Performance 6 10-24-2002 02:39 PM
help needed! Turbo plumbing P11GT Engine 3 12-17-2001 02:45 AM
