Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 01-17-2004, 03:14 PM
waymaster waymaster is offline
Courtesy lights stay on.
I have a 1992 Bonneville SE, when I close the door the courtesy lights come on and stay on. I have to slam the door a few times to get them to shut off. Sometimes they come on in the middle of the night after the the doors have been shut a couple of hours. Any suggestions?
Old 03-01-2004, 11:22 PM
PontiacRyder PontiacRyder is offline
Re: Courtesy lights stay on.
I have the same problem with my 1992 bonneville..When i close the door the light eather stays on or comes on in a few seconds... i pulled the courtesy light fuse for a quick fix cause it kept killing my battery....it would be greate to find out how to fix the problem....
Old 03-07-2004, 12:40 PM
markwb's Avatar
markwb markwb is offline
waymaster wrote:
Code:
It appears that the door switch(that tells the control module that the door is closed) is on the verge of being defective. That's just a guess.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 03-07-2004, 05:11 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Originally Posted by markwb
waymaster wrote:
Code:
I would agree. Your door switch just provides a ground for the light circuit. Likely the plunger is worn or the spring inside is broken, allowing the switch to find a ground when it shouln't. Those switches are cheap and very easy to change.
04 Envoy Battery light stays on mattwiant Envoy 2 04-28-2010 09:26 PM
Security Light stays on bsalters182 Silverado 1 09-21-2009 10:27 AM
Map lights stay on... cs2009 Bravada 2 07-01-2009 01:28 AM
dome, courtesy lights staying on zstorm22 Grand AM 1 09-25-2005 07:10 PM
Re: courtesy lights stay on bonnyl92 Bonneville 1 10-26-2004 12:19 PM
