Old 01-17-2004, 02:00 PM
diamondxt diamondxt is offline
Water pump 2000 Subur.
Think I need to replace the water pump on my 2000 Suburban. I have heard this is a common problem on them? Have also been told to flush the coolant and refill with normal coolant? 5.3 with 80000. Thank you for any help and or answers.
Old 01-18-2004, 08:57 AM
Tat2dBrownDude's Avatar
Tat2dBrownDude Tat2dBrownDude is offline
Re: Water pump 2000 Subur.
What exactley are you asking? I am little confused about the question. Do you want to know how to switch the water pump for a new one or if you should replace the red coolant for the yellow coolant? Or if the water pump needs to be replaced or if they go out alot? Try to be a little more specific on your question or questions and maybe someone can help.
Also I have had to replace a few water pumps on those, but being in Flint MI they are a common engines, so I am not sure if that makes it a common problem, but if you need to know how to replace it let me know. And I would stick to the red coolant, unless you need to save some cash. If you do switch then you have to flush all the red coolant out, you cant mix them.
"The Anti-JEEP"
Costs on water pump for 97 Grand Am? CindyLynn Grand AM 1 12-02-2010 02:06 PM
1995 cutlass supreme water pump 3.1 moemo Cutlass Series 1 05-02-2010 08:55 AM
1986 trooper 2 water pump replacement csurge Trooper | SLX | Bighorn | Wizard 1 11-02-2009 07:12 PM
timing belt and water pump :( cobraprince 3000GT/Stealth 17 07-09-2009 03:28 AM
Water Pump Gasket & Sealant/ Tensioner O-ring Questions Make 'em Last Grand Prix 2 06-06-2009 01:17 PM
