Old 01-15-2004, 08:34 PM
blade34609's Avatar
blade34609 blade34609 is offline
SI head Cam LIne Up?
Hi,
I am putting the SI head on my STD hatch and we already got the head on, header, hoses, manifold, wires, dizzy, and basically everything.
I just gotta set my crank at TDC and set the cam at TDC.
But if I use the SI head where abouts do I set up the camshaft?
Cause there is a setting for the DX or the SI.
Wont I still use the one I had before?
Thanks
1990 Honda Civic LX
5 Speed
1.5 Liter SOHC
K&N Cone Filter
APC Short Shifter
1988 Honda Civic STD Hatch
D16A6 Si swap
DX 5 Speed Tranny
90' CRX Si Gauge Cluster
Accel Performance Wires
92 ex timing belt not lining up at TDC (cam pulley/crank pulley) Swansen '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 04-01-2009 11:02 AM
Cams won't line up on 95 Intrepid 3.5 Mechslow Intrepid 1 04-08-2007 11:29 AM
How do you hook the cam sensor up on a 1g head to a 2g car? Talon69 Engine, Transmission and Drivetrain 7 02-23-2006 10:52 PM
WTT KLZE heads,CAMS! 4 98+ Milli heads!! senatorfrisky Millenia/Xedos 9 1 01-25-2006 10:01 AM
Cylinder head torque specs/ cam line up before putting head on black 95 Off-Topic 1 10-13-2003 10:06 PM
