Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 01-14-2004, 11:12 PM
sofunkingcool sofunkingcool is offline
4wd
hey guys I am having a problem with my 4 hi on my 96 sierra. Not engaging so I thought okay it is the actuator so I put in the new so called update with the wiring harness, all seemed to be good until till today the (day after)4 hi kicked out by itself which it did before also, and I could not get it to go back in. 4 lo works fine. Confused? I am I am going to try an reset the comp tommorow. also the fuse is good checked it. Does any know what else is could be?? I don't want to have to bring it in Thanks guys.
Old 01-16-2004, 02:21 AM
wrenchhead455 wrenchhead455 is offline
Re: 4wd
I guess my suggestion is to check any wiring that has to do with the actuator. I mean otherwise you'd probably have to take it in and have a pro check it out....good luck anyway, hope you find the problem
Nick
4wd light blinks when i select 4wd or 4wd lo or hi and a4wd dan8395 TrailBlazer | Trailblazer EXT 2 02-05-2010 08:24 AM
4wd light blinking, shifts into 4wd, in 4wd grinds in tight turn 4x4passport1185 Rodeo | Passport | MU 2 09-22-2007 08:07 PM
Why not 4wd on highways? Hums in 2wd not 4wd chcknugget Blazer 8 11-19-2005 05:39 PM
96 4wd/4wd low flashing lights cntrchfrk Explorer | Explorer Sport Trac 0 10-08-2005 06:57 PM
Just bought my 2005 Sport v6 4wd. Some switching 4wd ? frank69m 4Runner/GX470 5 03-18-2005 09:54 PM
