Go Back   Automotive Forums Car Chat > GMC > Yukon
Old 01-14-2004, 09:17 AM
elijahkun elijahkun is offline
Angry My truck wont start
ok. this morning truck started fine. went to my girlfriend's place for about an hour, and when i went to start it back up, it wouldn't. thought it might be due to the fact that i have a tendency to let my gas get a litlle low so i went and put about 4 gallons into it. no luck, still wont start. so now i'm stuck. should i check the fuel filter and pump? any help would be great.
Old 01-14-2004, 05:25 PM
2000CAYukon 2000CAYukon is offline
Re: My truck wont start
First you need to figure out if it is fuel, spark or air. You need all 3 to run. If you don't have a fuel pressure gauge, then you can spray a little starter fluid into the throttle body. If it starts for a second, then you are not getting fuel.
If it does not start, check to see if you are getting a spark.
Good luck.
//2000CAYukon
Old 01-15-2004, 01:37 PM
thanks for the reply. well, i don't have any fuel pressure. filter is clean. fuel pump relay is good. pump is getting correct voltage. guess i'll be replacing the pump.
Old 01-15-2004, 10:15 PM
herefordman herefordman is offline
If you can't hear the pump whine when the key is first turned on, then the pump is probably smoked.
94 honda cranks but wont start help please supermikeq '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 07-19-2009 06:00 PM
87 jimmy wont start Chevygirl04 Problem Diagnosis 1 04-09-2009 06:44 PM
replaced gaskets, now truck wont start....helpppp 97sierraz71 Sierra 3 02-28-2005 09:59 AM
Truck wont start, not getting gas. subijitsu Pick-Up 3 06-19-2004 11:49 AM
help truck wont start H22dave C/K 5 02-25-2004 02:23 AM
