Go Back   Automotive Forums Car Chat > Toyota > MR2/MR-S
Old 01-13-2004, 10:29 PM
fedupmr2 fedupmr2 is offline
fed up help me choose a motor to swap
ok im about sick of being that guy who gets blown away at every red light dont get me wrong for a 1.6ltr my mk1 can get going but not nearly as fast as i want it to. So heres what im going to do, im going to swap motors i have 4 basic choices whether they work or not is another matter. First the common 4agze or the ever so famous 4age 20 vavle. but what i really want to do is shoot for the newer mr2 motor the 3sgte will this work i dunno i was hoping you could help me with that answer?!! and last but not least is the honda b16a 170hp v-tech comes from a honda and is front wheel drive will that work no idea has it been done no idea what are your thoughts?..im willing to spend up to $3000 usd to make this car run with the best of the best please guide me in the right direction for i am clueless..lol
Old 01-13-2004, 11:16 PM
ac427cpe's Avatar
ac427cpe ac427cpe is offline
Miata is always the answe
Send a message via AIM to ac427cpe
well... for 3000 usd, i'm not sure. how good are you with a welder and plasma cutter? and how competent are you at automotive wiring? you have to be very good at all of these to even contemplate doing the last two swaps. i've done a 3sgte swap into my mk1, all that's left is the exhaust *which i'm waiting for at the moment*. and let me tell you... it was probably the most fustrating thing i have ever done! and i'm not even sure i did all the wiring correct! i'd say lean more towards the 20v 4ag engine, i've seen a turbo one of those before... but i'm not sure if it's in that budget. with the 3sgte: you have to remember that along with the engine, you will also have to buy an intercooler that can be made to fit, new driveshafts that fit, do the mounts + wiring, and lots of various other things. paul woods did a great write-up on his adventure in making one - here's the link http://www.mr2mk1club.com/turbo.html
i wish you the best of luck with whatever you do, but of those choices either of the first two would probably be the easiest. i'd say go for the 20v or a 20v turbo if you can find one, because i assume there wouldn't be any mounts to make, you could probably use the existing hardware.
hello, i am Dan
No more project cars. I wonder how long that will last...
Old 01-13-2004, 11:44 PM
most likely going 20vavle
after a few minutes of going back and forth between the 20 vavle specs and the 4agze specs theres not much of a diffrence so im going to go 20 vavle. but heres my issue. Can i just buy the motor or do i need the harness and ecu?
Old 01-14-2004, 12:27 AM
ac427cpe's Avatar
awesome, you will definately need the ecu, but that usually comes with the engine (as a package, engine, tranny and ecu). i suggest you contact Bill Strong if you really want to know more, he's on this forum evey now and then but is the power over at the mr2 boards http://www.board.mr2faq.com
he has a 20v powered mk1, and would probably be the best person to ask. check around on those boards, i'm sure he's written something about it. gl with the swap! keep us posted!
hello, i am Dan
Old 01-14-2004, 11:31 AM
1QUICK2 1QUICK2 is offline
Take the 3k and buy a cheap mk2 turbo, MBC and intake. Way more power than the swap will make, and more potential
93 MR2 Turbo-.20 over JE pistons,T3/04E 57 trim w/.63 AR,Intake,Greddy profect b spec 2 BC, APEX'I GT spec exhaust,Apex-i S-AFC, Turbo timer,550cc injectors,HKS trunk mount IC, B&M s/s,SPEC stg3 6puck clutch, TRD springs. Autometer gauges, PCP reverse indiglo gauges. P/P head,Intake, 17" SSR repl, Kaminari front lip and sides.338whp/272lbs tq at 18psi
FOR SALE! email: [email protected]
http://members.cardomain.com/1quick2
Old 01-16-2004, 03:18 AM
DWF Engineering DWF Engineering is offline
Dude! I have two AW11s (MKI MR2). Get a cherry-bomb or glass-pack muffler, straight pipe your cat, and header. Make your own intake so that the air has a strait shot to the intake manifold. Buy the WEB RACING #577 grind cams. Raise your fuel pressure to about 57 psi. You'll be pulling 15 flat. That 4A-GE is a good engine. Get a light flywheel and light pulleys; you'll have a real rocket.
My yellow MR2 had cams, intake, exhaust and would torch any neon, civic, eclipse, whatever...
It was faster to 30 than the TransAms and SSs that ruled the streets.
Old 01-16-2004, 11:52 AM
Re: fed up help me choose a motor to swap
faster to 30? where will that count? and "striaght piping" everything will only lose torque if its N/A. Just buy and SW20.
Old 01-18-2004, 01:45 AM
I've heard that the staight pipes causes loss in the low end but seeing as how I tried it and it made it faster, even in the low end, I'd say its not true. And what's 0-30 good for? How about The LS1 powered F-Bodies meeting me at the stop light and I rev the engine, the guy in the SS or Trans AM honks and says no race because he doesn't want to be seen being scorched off the line. How is that for a power trip? Between stoplights, I was fast enough they have no Idea I'm only pulling 15s!
Old 01-18-2004, 04:59 PM
MR2-AW11 MR2-AW11 is offline
Get 7rib block, second gen GZE? Upgrade it, play around with it. Much quicker route to power then 20valve. Naturally aspirated route takes too much time/money/etc...
GZE route can go turbo so can the 4age NA but.. the older 4age block well.. not good for turbo route.. of course after market fuel managment, spark, etc... would be required for reliability/maximum performance/fuel mpg/etc... stock computer is pooey.
So bottom line imo is last 4agze you can get your hands on Plus if i'm not mistaken the 4agze has far more torque then any other 4age.
help please !! motor build question!! Derrick12556 Mirage 2 12-27-2009 05:31 AM
350 motor swap bowtieballs2000 Performance 0 03-09-2009 10:26 PM
PLEASE Can't someone help with motor swap razmudtaz C/K 1 05-21-2004 01:41 PM
i need help with motor swap case245 Engineering/ Technical 1 08-02-2003 03:06 AM
need help with motor swap canned4thgen '88 - '91 Civic | CRX | Wagon | Shuttlee 9 04-25-2003 11:28 AM
