Old 01-13-2004, 04:58 PM
97civiclx's Avatar
97civiclx 97civiclx is offline
what ecu do i have?
i was wandering what type of ecu i have?
i am going to be swapping in a d15 b from h motors online and was wander ing if i can use my ecu or if i have to get a different one. also this engine is obd 1 mine is obd2 will that make a difference?
Old 01-13-2004, 05:37 PM
CivicEXRider's Avatar
CivicEXRider CivicEXRider is offline
Probably a P2P ODB2a ECU. Also, why in the world would you go from a 1.6 to a 1.5? There are conversion harness's for ODB2 to ODB1. Most logical thing would be to get D16Y8 and drop it in with no problems.
Old 01-14-2004, 02:23 AM
shmaptoe shmaptoe is offline
Send a message via AIM to shmaptoe
jdm d15b is a good choice. its got more hp than a z6 and a real nice r/s ratio for a d series. also im pretty sure its got a stock lsd. you will prolly need a new ecu. yours is located on the passenger side under the carpet on the floor. the 3 digits in the middle of the #'s are your ecu code.
for those i love i will sacrifice...
Old 01-25-2004, 08:03 PM
EKCivicVTEC EKCivicVTEC is offline
Re: what ecu do i have?
to put this swap in without a check engine light,you're gonna need the d15b ecu which is the p08,and an obd 2 adapter,otherwise you will have a check engine light because there is nowhere to plug your knock sensor(timing) onto the jdm motor.i swapped this motor into my 96 ex.
What ECU does a 95 GSR have? RedRocketGSR Integra 9 01-24-2004 08:56 AM
what ecu with jdm d15b outofstep '88 - '91 Civic | CRX | Wagon | Shuttlee 9 12-08-2003 04:45 PM
What ECU To Use W/ D16Z6??? erbinone '88 - '91 Civic | CRX | Wagon | Shuttlee 5 01-20-2003 11:13 AM
what ECU should be used for the B16A engine? bamer02 Engineering/ Technical 1 03-29-2002 10:21 PM
