Old 01-20-2003, 02:59 AM
erbinone's Avatar
erbinone erbinone is offline
What ECU To Use W/ D16Z6???
Which ECU is better to run?? Gonna be my daily driver & what are the advantages to each dif. one?
Old 01-20-2003, 07:38 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
you can run the p28...advantage-its the ecu that goes with the engine...takes a little wiring and a adapter harness
pm6 and some kind of vtec controller...advantage-easy... disadvantage-may lean out in higher rpm..
pg7 and some kind of vtec controller...advantage-easy....
SOLD!
Old 01-20-2003, 10:01 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
I would say to go with the p28. They are starting to get a bit expensive too, now that Honda Data has come into the picture. The p28 is the BEST ECU to use for Honda Data and the p28 can be programmed to run a B18c, because of that everyone is buying them and the prices are getting jacked up.
Old 01-20-2003, 10:38 AM
erbinone's Avatar
P28 sound like the way to go. What is Honda Data??
Old 01-20-2003, 10:48 AM
erbinone's Avatar
PG7 is out of what year teg??
Old 01-20-2003, 11:13 AM
marked001's Avatar
Moderadur
hondata makes reprogrammed/programmable ecu's.... $$$
the pg7 is out of the 88-89 teg.
SOLD!
