Old 01-13-2004, 12:13 PM
Jared_80 Jared_80 is offline
Banned
What determines the limit of cylinder pressure?
What is the limiting factor in increasing boost pressure? Is it the temp, is it the thickness of cylinder walls, or is it the fuels resistance to detonation? I remember reading about a Lotus race car runing over 100psi of boost. What made that engine so different from the high strength turbo blocks that we have today? If all temp problems could be controled with the addition of some kind of direct port water injection what would there be a limiting factor other than the strength of the rotating assembly and block?
Old 01-13-2004, 01:01 PM
ivymike1031 ivymike1031 is offline
Send a message via AIM to ivymike1031 Send a message via Yahoo to ivymike1031
Re: What determines the limit of cylinder pressure?
did you want to know about increasing boost pressure or increasing cylinder pressure? They're not the same...
Come on fhqwhgads. I see you jockin' me. Tryin' to play like... you know me...
Old 01-13-2004, 02:22 PM
MustangRoadRacer's Avatar
MustangRoadRacer MustangRoadRacer is offline
1. what ivy mike said
2. direct port water injection is crap
3. the limiting factor is tied into all of what you said.
Increasing boost increases temperature, which, in addition to pressure causes detonation if the fuel has a low octane rating, which damages the internals of an egine (rotating assembly and block).
Mustangs are nice, but I'd rather have one of these...
Old 01-13-2004, 04:46 PM
454Casull 454Casull is offline
Water injection does let you use more boost.
Some things are impossible, people say. Yet after these things happen, the very same people say that it was inevitable.
Old 01-13-2004, 05:23 PM
kfoote kfoote is offline
Adding to the list of potential limiting factors:
Head gasket material/strength
Cyllinder wall thickness/strength
imporities in the valve seat/valve surface
Piston ring strength
Basically, it depends on the engine and what has been done to it. The highest boost I know of that was reliable was 120 PSI in the 1993 Toyota GTP engine. They managed to get 1200 HP out of a 2.2L engine that won the 24 hours of Daytona.
2004 Subaru Impreza WRX STI (daily driver)
1999 Mazda Miata (track car, slow, but finished the SCCA Runoffs)
1987 Porsche 944 (being rebuilt)
Old 01-13-2004, 05:52 PM
pod pod is offline
Re: Re: What determines the limit of cylinder pressure?
wtf
30 mpg in a brick on wheels isnt half bad...
Old 01-13-2004, 05:57 PM
SaabJohan SaabJohan is offline
120 PSI is hardly the boost pressure since single stage turbines can't get enough power for this kind of boost. The highest boost pressures used in racing as I know of is 4.5 bar in the old F1 engines.
The 1200 hp Toyota engine has probably a boost of around 3-3.5 bar.
Old 01-13-2004, 08:22 PM
Sluttypatton's Avatar
Sluttypatton Sluttypatton is offline
You mean the old Toluene fueled F1 engines right?
Beer tastes better upside down.
Old 01-14-2004, 08:49 AM
Yes.
Their fuel was toluene based but contained some even nastier stuff. The fuel was the biggest reason for the increased power output (and therefore increased cylinder pressure). The synthetic fuel could however cost as much as $300 per liter but was 60% more dense than normal gasoline and contained a lot more energy.
Old 01-14-2004, 09:20 AM
Neutrino's Avatar
Neutrino Neutrino is offline
Yaya Master
Send a message via AIM to Neutrino
i believe that they used toluene in old F1 turbo engines because of its particularly good knock resitance
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination
Old 01-14-2004, 03:12 PM
http://www.allamericanracers.com/eagl_mkIII_gtp.html
That's got the specs, and I apologize, the car was de-tuned for the 1992 and 1993 seasons due to air restrictors limiting the boost pressure. These engines did not have head gaskets, and I believe at their most powerful, they were some form of multi-stage turbocharger. This car still holds the track record at Lime Rock (with the chicaine it lapped faster than any other car has without the chicaine). The rules that this engine was originally built to were not as restrictive as the mid-80's F1 engines (which did have more power and less displacement), with a few additional years of R&D. This was Toyota's biggest factory involvement at the time and they put a LOT of money into it.
I believe the cars at the time had to run a spec methanol fuel, but I'm not 100% sure of that.
Old 01-14-2004, 03:59 PM
Not only knock resistance, energy content and density was very important since they were limited to a maximum volume of fuel for the races.
Some of the contents are said to be aniline, coumarine, cresol, cumene and naphthaline.
Old 01-14-2004, 07:18 PM
It used a single, quite large turbocharger. I believe the engine was also used in TOMS Toyota LMP and Rod Millens Pikes Peak cars.
The Eagle was infact constructed very cheap, they even used vacuum bags instead af an autoclave since they didn't had any.
The power output was 750 hp in 1992 and 700 hp in 1993.
The biggest reason for its success was probably the aerodynamics, the use of a front diffusor.
The use of no head gaskets is also used in F1, the head and block is polished to a very high finish so they will seal without a gasket.
Old 01-15-2004, 12:08 PM
Re: Re: Re: What determines the limit of cylinder pressure?
I'm not sure about the TOMS Toyota LMP, but the engine was used (unrestricted) in a couple of Rod Millen's Pikes Peak cars (and a Pikes Peak Toyota Tacoma as well, I believe)
Old 01-15-2004, 12:34 PM
Banned
Read the book Turbocharging. They point out that a water injected engine can run 70% higher pre-ignition pressure without knocking. That is more boost pressure in my book.
What is the best tyre pressure? Spunkymonkey Asia/Pacific 15 03-17-2016 04:30 AM
What is the proper air pressure? vanbc Festiva 1 11-19-2007 06:13 PM
What is the stock fuel pressure? vanilla gorilla Engine, Transmission and Drivetrain 1 07-02-2006 11:01 PM
what is the recomed tire pressure for 17" aftermarket rims? IronAuroraV8 Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 5 08-12-2004 08:10 PM
205/40/17 : What is the Proper Tire Pressure?? jeffseby Tires and Wheels 8 06-29-2004 11:14 PM
