Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 06-28-2004, 07:11 PM
jeffseby's Avatar
jeffseby jeffseby is offline
Send a message via AIM to jeffseby
205/40/17 : What is the Proper Tire Pressure??
I got Kumho 711HR "205/40/17" tires, what is the correct tire pressure for this please?
Ya, It's Turboed.
Old 06-28-2004, 09:44 PM
knorwj's Avatar
knorwj knorwj is offline
Send a message via AIM to knorwj
most tires tell you on the sidewall.
Old:
1993 Acura integra gs-r
New:
1998 chevy BlaZeR2~ AKA "Jeep recovery device"
Newer:
2007 Honda CB900F "919"
Old 06-29-2004, 12:49 AM
BullShifter's Avatar
Re: 205/40/17 : What is the Proper Tire Pressure??
"Sidewall" psi is for the tire at it's maximum load. look inside your glove box for the rec. tire pressures(29psiF/R i think)
Slightly lower pressure will soften the ride w/ increased corner stability & a slight decrease in gas mileage.
Slightly higher will harden up the ride & increase gas mileage.
Running the front lower than the rear helps any FWD car in handling.
Old 06-29-2004, 11:21 AM
knorwj's Avatar
well the problem with that on these particular tires jackassi is that when you run at 29 psi the side wall is practically non existant and you rims get chewed up. by the way I have these same tires on my teg.
The sidewall maximum pressure is 35 psi and I have run them at 28-29, 32, and 35.
35 is very rough ride, 28-29 the slightest little hiccup in the road and the rims get dammaged, right now I keep them all at 32 and it seems to be a somewhat happy medium.
I only recommended looking on the tire to get a general idea, if the tire says 35 then I hope he would not go over that, and have a better idea of where to start.
By the way you mentioned to look in the glovebox? wouldn't that pressure be the old stock tires? will it still apply to new different style tires? I've always assumed that different tires needed different pressures and to go by the manufactureser rating of that particular tire?
Old:
New:
Newer:
Old 06-29-2004, 01:39 PM
CivicSiRacer's Avatar
CivicSiRacer CivicSiRacer is offline
Civic Mod
Send a message via ICQ to CivicSiRacer Send a message via AIM to CivicSiRacer
I recommend higher pressures incase you hit a pothole - it will at least try to protect your rim better.
I ran around 40psi front and rear in my 17s.
Sponsored by: KAM Racing Sports, Falken Tires, Finish First Polish, Brady's High Performance, Taggart Performance Engineering, Rotora Brakes
Autocross is: 90% driver, 5% car, & 5% CRAZY MOJO!
Autocross Help Page
Buy my Civic parts!
Old 06-29-2004, 02:28 PM
jeffseby's Avatar
Acually my sidewall says "43 PSI Max" On my old 17s I was told by WheelMax to run at a constant 40 PSI, unless the guy over the phone was wrong. Every time I go to get my Oil changed they lower it to 35 PSI, but I think thats wrong.
Ok, I just called the guy at Wheels Next and he said "36 PSI", but he sounded kinda stoned; so I will go at 37 PSI.
Ya, It's Turboed.
Old 06-29-2004, 07:31 PM
Re: Re: 205/40/17 : What is the Proper Tire Pressure??
my bad I didn't read the whole thing . . . . .36-40psi would be ideal
Old 06-29-2004, 09:34 PM
Civic Mod
Why do you have someone else changing your oil? Do it yourself so they will stop messing with your car.
Autocross Help Page
Buy my Civic parts!
Old 06-29-2004, 10:14 PM
jeffseby's Avatar
Well I know half the people that work a valvoline, I live right next to it, so they here my turbo all the time. they know me to. I am watching them as they do it though. I don't just sit down and let them have there way. I just forgot to tell them not to fuck with it. Plus I live at an apartment, its a little hard to lug out the jack and stands ECT. you get the point.
Ya, It's Turboed.
