Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 08-12-2004, 07:51 AM
IronAuroraV8's Avatar
IronAuroraV8 IronAuroraV8 is offline
what is the recomed tire pressure for 17" aftermarket rims?
I runing 225/45-R17 and i have the fronts at 34psi and rear at 32psi
which seems very comfortable to me, but yesterday i had them balanced
and the shop got them tires all the way up to 44psi !!! which made the ride very stiff and unconfortable.
what psi on 17" rims you guys find most comfortable.
thanks
Old 08-12-2004, 11:20 AM
Re: what is the recomed tire pressure for 17" aftermarket rims?
anyone?
Old 08-12-2004, 03:30 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
if the tires are low porfile then the tire pressure should be maintained pretty high. i was told to keep mine at 45-50 psi. i have 235/35/ZR19's though.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 08-12-2004, 04:51 PM
Swonder67 Swonder67 is offline
Send a message via AIM to Swonder67
Re: Re: what is the recomed tire pressure for 17
Same, I got 35 profile tires too.
2003 Nissan Maxima SE Titanium Edition
Cattman Catback Exhaust
35% Platinum tint
Old 08-12-2004, 04:54 PM
wow !!! that high, the sidewell says 44psi is max
but there is no way i can drive my car with tires pumped up that much - she was vibrating a lot with 44psi at 80mph
with around 34-36 things are much smoother
Old 08-12-2004, 07:10 PM
rule da road rule da road is offline
Send a message via AIM to rule da road
44 psi max, as per tire rack, also. i had mine on 32 psi on those same tires until i found out but i enjoyed the higher psi. Try 40 since the hi is supposed to 44 but remember fuel consumption. Hesitation? That should be checked out on those tires. Notify that shop and hear there recommendations, make sure the tires are in tip top shape.
