Old 01-12-2004, 06:23 PM
avf925 avf925 is offline
Question Re-Programming Keyless Entry FOB - 2001 Taurus
Where can I find instructions on how to do this ?
Thanks in advance !
Old 01-26-2004, 03:53 PM
bjw1960 bjw1960 is offline
Send a message via Yahoo to bjw1960
We have a 2000 Taurus. I found this in the owner's manual. It may help you. It worked for me.
Have remote{s} ready. Have doors unlocked. Turn the ignition switch from on to off, 8 times quickly{without starting vehicle}.
After the 8th time, the doors will click to lock. Immediately push any button on the remote. Repeat for additional remote.
GOOD LUCK!!
Bill
Old 04-18-2004, 09:44 PM
thepartsyouneed's Avatar
thepartsyouneed thepartsyouneed is offline
Banned
Re: Re-Programming Keyless Entry FOB - 2001 Taurus
This procedure works for 1998 + Taurus models:
Cycle Ignition from OFF to RUN 8 times within 10 seconds, ending in RUN. All doors will lock then unlock to confirm programming mode. Press any button on 1st remote transmitter. Door locks will cycle to confirm programming. Press any button on 2nd transmitter ( up to 4 transmitters total possible ). Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
I have these remotes available in my Ebay store.
Old 08-02-2009, 10:35 AM
ta86man ta86man is offline
Hello i have a 2004 ford taurus and i have tried this procedure to program a used keyless entry remote and it doesn't work.
When i turn the car on and off 8 times, the car doesn't lock it self ?
Help is there a fuse that blown that operates the programing?
The power locks work when you hit the lock button inside.
Thanks,
jim
Old 08-02-2009, 05:13 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Welcome to the forum!
When all else fails, check the owner's manual. If you have the owner's manual for your car, check out the procedure which starts on the bottom of page 78. If you don't have the owner's manual, you can download the PDF here.
-Rod
Old 10-10-2009, 05:10 PM
ANZUS1966 ANZUS1966 is offline
It does work, i got a remote form a 98 escort at the salvage yard. it worked on my 01 Taurus and then i programmed it for my wife 98 escort. now when I press a button it operates on both vehicles at the same time.
Programming Keyless Entry for MAZDA 6 Mazda6ownr 6 7 09-26-2013 04:46 AM
Programming Keyless Entry Fob ybrady Explorer | Explorer Sport Trac 17 07-01-2008 11:32 PM
2000 Buick Century Re-programming Keyless entry fob copierfixerguy Century 4 03-19-2008 08:42 PM
Programming Keyless Entry FOB for ZJ's ZJbumping Grand Cherokee | Grand Cherokee SRT8 5 10-31-2004 01:18 PM
Programming keyless entry fobs whiteoak56 Malibu 4 05-14-2004 07:08 PM
