Old 01-12-2004, 01:54 AM
caljeep caljeep is offline
1990 Testdrive noise
I testdrove a 1990 Cherokee (manual everything - basic), 129K, $2600, 2nd owner, mostly good everything...with the exception of a whirring/humming noise coming from the rear of the vehicle in between accelerations...was disturbing...what could this noise be?...owner said maybe it was something called a differential....is this car still a good deal if this differential needs repair?....
...buying this car to drive cross country from California to Vermont...am I crazy?...or should I pursue....
Old 01-12-2004, 08:01 AM
EquityDog EquityDog is offline
No way to know without having someone who knows car mechanicals look at it. Maybe it is just low on oil; easily fixed. Maybe there's some bearing or bushing wear; will need to repair it eventually but it will probably get you to VT. Maybe things have worn enough to spoil the precise alignment of the gears. If that happens, you could have a tooth break on a gear and jam everything up. If that happens while you're driving, the rear end will lock up and skid. That can be pretty exciting and dangerous.
The differential is an essential mechanical unit and I wouldn't begin a long trip without having it checked out.
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
1990 Ford Econoline Van Radiator Problem, I think.. ariel418 Econoline 6 05-12-2009 06:40 PM
1990 right front driveline vibration dieter LeSabre 2 04-04-2009 08:16 PM
1990 735i Noise When Slowing Down or Idling jrs811 7 Series 2 07-19-2006 05:07 PM
1990 Legend noise from left rear Lena Legend | RL 0 03-28-2002 04:31 PM
