Old 01-11-2004, 04:34 PM
johnbu johnbu is offline
Check Engine Light - 97 C/K 5.0 L
My check engine light is flashing...upon checking the codes at Autozone two problems were listed:
1. Cylinder 7 misfire
2. O2 sensor
Unfortunately, the guy at autozone was in a hurry so he checked the codes and reset them and had to run. I did not have a chance to write them down. However, I decided to perform a tune-up ..plugs, cap, and rotor...now I am left with just:
1. Cylinder 7 misfire....
I did check the plug wires...they look good and they boots are still securely fastened.
Any ideas?
Does anyone know of a computer program and cable that can be installed on a PC to read OBDII codes?
Any help is appreciated.
Old 01-12-2004, 02:57 PM
RABarrett RABarrett is offline
Re: Check Engine Light - 97 C/K 5.0 L
The misfire code can set the O2 code. Check carefully the misfire, and make sure it is fixed before going for the O2 sensor. A misfire will cause extra O2 in the exhaust, confusing the system into thinking the O2 is the culprit. Ray
Old 01-12-2004, 05:14 PM
Re: Re: Check Engine Light - 97 C/K 5.0 L
You are correct. Upon performing a tune-up the 02 code went away.
Now I am left with the Cylinder 7 misfire code. Any ideas?
Old 01-12-2004, 07:59 PM
nusch nusch is offline
Have you tried running any injector cleaner through? The injector for cylinder 7 might be a little dirty.
Old 01-12-2004, 08:08 PM
I did try injector cleaner and I just replaced the #7 plug wire and had the same results - cylinder 7 misfire.
Old 01-12-2004, 09:25 PM
The only thing I can think of except for what you have already replaced would be a leaking or broken pintle valve inside the injector. That would mean you would have to replace that one injector, but hopefully someone else might have a better idea of what it might be or what you could do.
Old 10-25-2005, 11:43 AM
borninski borninski is offline
Switch the plug wire around with one of similar length to a different cylinder and see if the misfire travels to the other cylinder.
After working at an auto shop/State Inspection Station for a while I have never seen a case where a misfire could not be remedied with a full tune-up. Whenever we see someone fail an inspection due to a misfire we always recommend spark plugs, spark plug wires, distributor cap and rotor replace and sometimes new PCV. Like I said, I have yet to see someone still have a misfire after a complete tune-up.
96 Eclipse rs 2.0 non turbo Check Engine light donidavis Eclipse Problem Diagnosis 6 12-02-2010 08:39 AM
Check Engine Light..... Stinff Equinox 2 11-01-2010 10:15 AM
97 ram 4x4 shaking, check engine light on, one tire is wrong size cscafe Ram Pickup | Ram SRT10 2 11-18-2009 02:53 PM
Check engine light on 89 cherokee hoopdaddy6 Cherokee 3 04-09-2009 05:16 PM
1994 Ranger 4cyl check engine light/ABS light wont start on cold mornings 94rangerproblems Ranger | Courier 1 03-21-2009 06:40 AM
