Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-29-2010, 12:12 PM
donidavis donidavis is offline
96 Eclipse rs 2.0 non turbo Check Engine light
Whats up guys... im having some problems with my Eclipse. I put a new engine in it about 2 mts ago and now its throwing 3 constant codes. The main one is 1487- High speed radiator fan control relay circuit fault. 1698- computer and the tranny not communicating. 1899- Neutral Safty switch. My car is a 5 speen but idk whats going on with it! can some one help me?
Old 11-29-2010, 02:11 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 96 Eclipse rs 2.0 non turbo Check Engine light
Did you change the trans or the ECU at all at some point recently?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 11-29-2010, 02:15 PM
well... i just put the engine in it but i used the same tranny that came in the car. but yea i had unhooked the ECU a few times.
Old 11-30-2010, 09:18 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
It shouldn't be throwing those codes if you didn't change anything but the motor. With a 5spd it should be throwing codes for the auto tranny. Im not sure if the auto ecus and 5spd are the same or not.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 12-01-2010, 07:23 AM
Na i dont think they are the same. but i wass told the tranny and engine is not communicating. so ima look and make sure no cords are broken.
Old 12-01-2010, 08:35 AM
david-b's Avatar
Dave is THAT guy
The only thing the ECU sees from the 5psd trans is the speedo. And if the ECU doesn't see speed, it won't throw a CEL. Plus, the 5spd doesn't have any sort of neutral switch.
Out of curiosity, in the engine bay by the ECU, do you have another unit next to it that looks like another ECU? Should be on the same braket
75 Monte Carlo
Old 12-02-2010, 08:39 AM
yea thats what i was thinking too about the neutral safty switch! but na its only one there! some ppl were telling me that it could be a crushed wire or something like that!
2.0 non turbo timing belt question duckman028 Engine, Transmission and Drivetrain 3 12-30-2008 03:37 PM
BATTERY QUESTIONS For 2.0 Non-Turbo Eclipse GS... SOME ONE WITH THE SAME CAR... boyertownMidnight Off-Topic 1 10-09-2005 06:01 PM
2.0 non turbo the~~kidd 1st Gen 95-99 36 09-13-2005 06:48 PM
96 Cavalier 2.2 ETS OFF and check engine lights both on 429CorbaJet Cavalier 2 05-29-2005 10:01 PM
Tags
420a , eclipse , engine , light , odbii
